Old 11-27-2004, 01:10 PM
jjct61765 jjct61765 is offline
HELP! Starter wont turn over
I have a 1996 Taurus wagon. I replaced the starter with a new one and it still wont start. Not even any clicking. The battery is fine. Please help!!
Old 11-27-2004, 01:17 PM
Cobra_Sam Cobra_Sam is offline
Re: HELP! Starter wont turn over
Your key ignition may have gone bad.
Old 11-28-2004, 10:26 AM
fordfool fordfool is offline
check your solenoid!
Old 11-29-2004, 09:27 PM
bluesdude bluesdude is offline
Could be a bad ground from battery to engine. Run a ground wire from starter directly to battery ground to verify. Had the same issue with a GM station wagon.
Old 12-13-2004, 09:27 PM
TomV TomV is offline
I hope you have solved you problem by now. However, probable sources include: faulty cables, bad gound point, faulty ignition switch or a faulty Transmission Range Sensor.
