Old 11-27-2004, 12:41 PM
Azure Edge Azure Edge is offline
Remote keyless entry?
I got my '99 Mustang base coupe (V6) from a used-car dealer. Remote keyless entry is listed as a standard option for my car, but the dealer didn't give me the remote that should have come with the car. Apparently the seller didn't give them one. Is there a place where I can order a new remote that can be configured to work with the existing system, or will I have to buy a whole new keyless entry system?
Old 11-27-2004, 12:48 PM
MARS's Avatar
MARS MARS is offline
Re: Remote keyless entry?
Yeah. If you have the STEALTH anti theft system like I do, you should be able to pick up a remote from the dealer. If it's an aftermarket symstem, then go to any car audio/alarm shop and they should be able to program it for you!
Old 01-04-2005, 12:10 AM
whitestanggt whitestanggt is offline
if its standard option, then it is factory, you can get one MUCH cheaper on ebay for your car.....to program it I think all you have to do is put it on your keychain, turn the key (ignition) on and off like 5 times, untill the doors lock. It should work then
'96 GT
screamin demon coil packs
10.5mm taylor wires
sst 2" lowering springs
sst shocks/struts
hotchkis caster/camber plates
upper/lower control arms
mac cold air intake
mac 2.5" off road pro-chamber
2.5" flowmaster 40's
steeda tri-ax shifter
cobra rr svo hood
daytona wing
euro cobra fender flares
side scoops
euro diamond clear headlights
