Old 11-27-2004, 12:33 PM
Civic DOHC Civic DOHC is offline
oil warning after swap
Hello,
Got en new crx enigine (d16a9) in my civic because the other broke down. After te swap the engine started and there were no problems.
A week later (to busy whit work) i had some time to finish my civic but after a few minutes the oil warning light turned on. Also has the head some more noize than usual. I think that the head isnt getting oil. On the engine is a new filter and oil.
Any sugestions what to check?
Old 11-27-2004, 02:53 PM
Hilikus Funkin's Avatar
Hilikus Funkin Hilikus Funkin is offline
Send a message via AIM to Hilikus Funkin
Re: oil warning after swap
isnt the a9 a DOHC ZC? do you mean a6?
1991 Honda Civic DX Sedan
Old 11-27-2004, 03:17 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
Do me a favor and dont drive the car till you figure out what it is. If you can get a hold of a dolley, take it to a shop. Have them check oil pressure and go from there (unless you can do it yourself). No oil getting to any part of the engine is a sure way to ruin it, quick.
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 11-27-2004, 03:23 PM
The engine hasnt ran for a time i think. D16a9 is a dohc engine
Old 11-27-2004, 04:15 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
head noise might be lifters needing adjustment
or its outta time and u mashed valves?
Old 11-27-2004, 04:17 PM
1PhatCX's Avatar
mine didnt run for over 9 or 10 months and it ran fine when i started it up
except for 2 injectors being clogged but that was fixed
Old 11-28-2004, 08:47 AM
can it be that the oil pump broke down?
Old 11-28-2004, 09:43 AM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
take the valve cover off and start the motor, seriously. If you have oil getting to the head you will definatly know. By the way I dont mean start it and run it, just long enough to see what happens.
As to dereks comment about ht 9 months, I have a motor that wasnt started for almost 10 years and I put a fresh battery on it and pour a little gas in the carb and it started up.
Old 11-29-2004, 03:48 AM
Oh you mean just start it by letting the starter motor run the motor. The spark plugs not conected.
Old 11-29-2004, 05:50 AM
Forunn Daberator
so um.. you know connect them.
Old 11-29-2004, 09:26 AM
if it is the oil pump, where can i find it?
Old 11-29-2004, 09:58 AM
Forunn Daberator
http://www.binghamtonlife.com/manual/2gsm/default.htm
Heres a Helms manual, it will tell you where its at and all the stuff you need to know.
Old 11-29-2004, 12:50 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
yup i once tried to start my car with my valve cover off, oil everywhere. you will know if its working or not. cause it wont be just alittle oil, it will be alot
Team Lonely Drivers
Old 12-02-2004, 10:39 AM
Checked my oil pan and there is a litle bit of oil comming out. If the oil pan has a leak can it be that there isn't anough oil presure?
Old 12-02-2004, 10:46 AM
Forunn Daberator
unlikely
