Go Back   Automotive Forums Car Chat > Honda > Integra
Old 11-27-2004, 11:23 AM
Tano016 Tano016 is offline
Type R cams in Gsr
Ok, So i know someone who's willing to sell me BOTH type r camshafts for 300$. From doing reasearch i found out that when installing type r cams in gsr you should install your gsr intake springs on exhaust side and buy new type r intake spings. Now when i opened up my hanes manual, it says that in order to change valve springs on a vtec engine you have to remove the cylinder head! I really dont want to do this, and i dont wanna pay someone since i know it's expensive. So my question is: if i were to install both camshafts without changing the valve springs,would i damage the engine in anyway?, and will i still see performance gains.
Old 11-27-2004, 12:21 PM
Crippy's Avatar
Crippy Crippy is offline
Re: Type R cams in Gsr
the gains wouldnt be very much without the springs , but you should be ok without them as long as you dont rev past 8 grand ...
2001 GSR ,
94 jdm b18c sir-g swap , i/e !!
Old 11-27-2004, 04:08 PM
gsr916 gsr916 is offline
Banned
Send a message via AIM to gsr916
you will still see performance gains but at high rpms you have the possibility of valve float, in which the pistons can possibly hit the pistons. then you will do damage. My friend had ITR in his b16 for quite a while and never had any problems, but i convinced him to take them out if he wasnt going to replace the springs.... i personally do not think it is a good idea.
Old 11-27-2004, 11:34 PM
i heard that if you dont change your redline on your gsr (which is 8250 rpm on the gsr and 8750 on the type r) there is no need to change your springs, is this true?
Old 11-28-2004, 11:08 AM
kornflakes28546's Avatar
kornflakes28546 kornflakes28546 is offline
the GSR redlines is 8000 not 8250. if your going to do internal work, just take the time and a little money and do it right...get the springs
Old 11-28-2004, 05:26 PM
whitGSR07 whitGSR07 is offline
gsr redlines at 8100
Old 11-28-2004, 09:34 PM
integraboy_2007 integraboy_2007 is offline
I'm pretty sure gs-r redlines a 8200 and type r at 8900
Old 11-29-2004, 07:36 AM
Please lets not start arguing over the stupid redline, we all know that the type r revs about 500 Rpm higher than the gsr (stock), so lets answer my original question: if i dont change the redline on my gsr, do i have to change my valve springs, i would like more than one opinion and actual experiences please. Please hurry since i have to decide soon, or the cams will be sold!
Old 11-29-2004, 07:39 AM
integralover's Avatar
integralover integralover is offline
it can be done without the springs. but it would be good to save up for those next.
93 teg LS
B20B
ACT Performance Flywheel
AEM CAI
DC Sports Stainless Steel Header
G4 High Flow Cat
GReddy MX Cat Back Exhaust
Skunk2 Racing Chip
Lots of interior goodies
Old 11-29-2004, 09:21 AM
b18ls's Avatar
b18ls b18ls is offline
Banned
Keeping the RPM's low will help, but that's not the answer to your problem. You should invest in new valve springs. The GS-R springs are not as strong as the ITR ones. This means you run the risk of valve float.
Old 11-30-2004, 12:40 AM
Dr.Gonzo Dr.Gonzo is offline
Send a message via MSN to Dr.Gonzo Send a message via Yahoo to Dr.Gonzo
Yeah do it right when it comes to cams or else engine and performance will suffer. From what I am getting is if you don't put in stronger springs you won't get the full potential out of the ITR cams. Why only do a half-assed job and risk hurting your motor? If you save up the money to have it done right you will be able to use the full power of the cams.
That would be like me spending the $2900 for Schrick 268's and a Techtonics Tuning big valve head for my VR6 and not getting heavy duty springs. Yeah it could work but I could also cause a lot of serious problems and mess up my engine. Get the point?
Old 11-30-2004, 01:50 AM
Sed8ed Sed8ed is offline
No your performance wont suffer from weaker valve springs... just your engine might.
If you check your honda part #s you will find that the outer springs on the gsr and the type R have the same part #s, furthermore the inner springs on the gsr have the same part # as those from the type R.
The difference lies in with the gsr which only has inner springs on the intake side and not the exhaust side (the R has them on both sides)
In order to equate them, install stock B16, B18c1-5-R inner springs on the exhaust side and you are good to go. Personally, I would just go and buy 16 portflow inner springs, install those and call it a day.
To change the valvesprings without removing the head, you can use compressed air to keep the valves in place... remove the exhaust mani and use a pressfit compressor tip to pressurize the cylinder you want to work on... make sure the cams are removed first.
Note... if your engine has more than 100,000mi on it then you are better off to pull the head and replace all gaskets while you are at it... it will save you time and hassles down the road
Old 11-30-2004, 09:58 AM
everything else you said may be true, but isn't this an oxymoron? engine health = performance? so if the engine suffers the performance WOULD suffer? i may have just read your post wrong
Old 11-30-2004, 01:02 PM
b18ls's Avatar
Banned
I'm not sure I understand this statement. Due you mean the GS-R's exhaust springs aren't dual springs? (a small spring inside a bigger one, see picture below). If so, this might be true, but still means those 8 springs should be changed!
Old 11-30-2004, 10:09 PM
Type r exhaust springs are the same as gsr intake springs, its the intake springs that are completely different
