Go Back   Automotive Forums Car Chat > Buick > Century
Old 11-27-2004, 11:30 AM
chatty chatty is offline
Brake Drums off How? buick century 92
I cant get my rear drum brakes off. Suppose to be a clip? I found two little round plugs but cant get them off? Please help. thanks chatty
Old 11-27-2004, 05:27 PM
yogi_123rd yogi_123rd is offline
Re: Brake Drums off How? buick century 92
It sounds like the shoes have worn a ridge into the drums. You'll have to loosen the brake shoe adjuster rod. The back of the backing plate has rubber plugs where holes are getting at the adjustor. Use a screwdriver to turn and loosen the adjustor rod.
If you can't unloosen the adjustor rod, then alternately, a second way of removing the drum is to cut the heads off the brake shoe retaining pins that protrude thru the back of the backing plate.
Old 11-28-2004, 10:05 AM
Re: Re: Brake Drums off How? buick century 92
Its like the plugs are metal and I cant get them off. Any specific info.? thank you so much for your time.
Old 12-19-2004, 09:00 AM
thank you so much. Finally got them off with a heavy duty slege hammer. The regular hammer just wasnt doing the job. Thanks for all the help. I love this forum.
