Go Back   Automotive Forums Car Chat > Toyota > Supra > Maintenance
Maintenance Have questions? Find answers. Help out fellow Supra owners.
Old 11-27-2004, 09:56 AM
jodeci227 jodeci227 is offline
Angry HELP! Alarm in kill mode & can't bypass alarm or turn off.
We bought a 1988 supra. After getting it home (& opening the door) the alarm went off. Evidently the previous owner forgot to tell us that there is a short in the drivers side door so that when the alarm goes off, u can't use the key to unlock the door and thus shutting off the alarm. We have tried everything, from unlocking the passenger side door with the key to unhooking the battery to reset it. We can't get it to even turn over. It seems to be in the kill mode.
Thanks for anyones help.
Old 02-06-2005, 03:21 PM
88supraturbo 88supraturbo is offline
Angry Re: HELP! Alarm in kill mode & can't bypass alarm or turn off.
try arming it again(red light flashing) then unlocking it from the pass side with the key. if that doesnt work then push it off i heard that doing this will disable the alarm to
Old 02-06-2005, 06:31 PM
Yellow 13's Avatar
Yellow 13 Yellow 13 is offline
Send a message via AIM to Yellow 13
You could just pull the fuse for the security system, its in the little box by the battery. It worked for my 89.
Old 03-16-2005, 11:23 AM
youngsuprakid youngsuprakid is offline
Talking Re: HELP! Alarm in kill mode & can't bypass alarm or turn off.
yup like the other guy said pull the fuse it works i had the same issue u did only my driver side door is a piece of shit and the key hole is jammed
