Go Back   Automotive Forums Car Chat > Eagle > Premier
Old 11-27-2004, 07:53 AM
Knifeblade Knifeblade is offline
Smile Mine
Well, I have an ES, '89, that i picked up for $200.00. Outside of normal maintenance, and that some of the electric accessories don't work too well, I have never had any prblems with the engine or trans. Took it to FL and back, round trip 1400 miles +/-. It never even wheezed. I have a manual and some additional info. on repair for the 88-92 series, let me know if I can help out.
Old 11-30-2004, 01:43 PM
Re: Mine
http://www.autozone.com/servlet/UiBr...Parameters=006 I strongly suggest this site for basic tech. information for your Eagle.
Old 11-30-2004, 01:50 PM
Re: Mine
And, if you have alignment problems, the culprit may be in the upper front strut towers. The bearings and bushings wear out quickly, replacement is required to tweak the struts to re-align the FE. Costly!!!!!!! But a DIY'er can lessen the cost easy 50% if they have the tools and inclination to do the work, which isn't hard, but time-consuming, and the usual BS of dropping a strut. And if your headlight relay goes west, it simple wiring to get the headlights to work, just look at the relay itself and two-wire the headlights to a inline switch with a 20amp amp fuse in-line. It works great, with minimal expense and effort.
Old 09-24-2005, 02:15 PM
thegodsmustbecrazy's Avatar
thegodsmustbecrazy thegodsmustbecrazy is offline
Send a message via MSN to thegodsmustbecrazy
Re: Mine
i could sure use a diagram of the motor. ill be canging the oil pump or chain.. im not sure were its at so if you can please send me a diagram of the motor or some info.
thanks john [email protected]
Old 01-02-2006, 01:28 AM
oljeeptek oljeeptek is offline
Re: Mine
Don't turn the engine backwards while working on it. It can break the timing chain tensioner.
Replace the seal behind the distributor. They leak a LOT.
Remember...
Old Jeeps never die, they just sometimes look that way!
