Old 11-27-2004, 01:40 AM
mikemac09 mikemac09 is offline
Unhappy Squeal upon engine start
I have a squeal that occurs right after the engine starts and turns over. It happens for just a second or two. Should I replace the starter motor? Or can I get away with just replacing the selonoid?
Old 11-27-2004, 03:14 AM
Technical_Automan Technical_Automan is offline
Banned
Re: Squeal upon engine start
That has nothing to do with the starter. It's either a belt or a pulley, most likely your water pump pulley. It's common for the water pump seal to go bad and leak coolant onto the pulley which makes it squeal, as it gets worse the squealing will continue longer.
Old 11-27-2004, 05:28 AM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
my starter is doing the same thing, and so are 2 of my friends starters that have 3S's, Im letting mine go until somethign worse happens. I cant think of anything bad that its causing, its just spinning the starter after the engine starts.
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
Old 11-27-2004, 02:40 PM
Banned
oh, that kind of squeal...like a high pitched "whirring"? Well if the starter is staying engaged too long that would mean the magnet in there isn't working as good as it should, so I think that's a whole starter replacement $80 i think.
Old 11-27-2004, 03:15 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: Re: Squeal upon engine start
lol starter is like $140. Thats the cheapest I found. Mine used to do the same thing. I had some issues that IU thought the starter were causing so I replaced it. Turned out to be something stupid but I kept the starter since mine was original with 130k on it.
Old 11-27-2004, 03:18 PM
Banned
Well I got mine for $80 at autozone 2 months ago, lifetime warranty. Maybe you got ripped.
Old 11-28-2004, 12:22 AM
Stealthee's Avatar
hmmm dunno. I dont get ripped off though cause I know my shit. Plus it was my friend who sold me the starter, he used to work at Advance. Mine may have been a lifetime warantee too. Maybe it was the only brand they had and I bought it cause I (though I) needed it. I can never remember anything anymore.
Old 12-02-2004, 09:55 AM
BB1970's Avatar
BB1970 BB1970 is offline
mines been noisy for the last 2 years, ive learnt to put up with it.mines only the pinion that is noisy.
1993 Mitsubishi GTO Twin Turbo (RHD) NOW SOLD!!!
9b turbos with manual boost valve mod set @14psi
turbo xs type h-rfl blow off valve
blitz dome filter
sachs clutch
completely de-catted
fuel pump voltage rewire mod
ebc redstuff front brake pads
greddy fully automatic turbo timer
now drives a sensible family sedan. A 340hp 1997 mitsubishi evolution IV
Old 12-02-2004, 11:25 AM
pr0ject01's Avatar
pr0ject01 pr0ject01 is offline
Send a message via AIM to pr0ject01
Is it the same for when you push on the gas at around 3000 rpm's? Because i get a squeal when i push on the gas (all gears)
1991 Dodge Stealth R/t
