Go Back   Automotive Forums Car Chat > Buick > Century
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 11-27-2004, 01:00 AM
BradN10 BradN10 is offline
Send a message via AIM to BradN10
Unhappy Lots of Problems!!!88'Buick Century
About a month ago I bought my first car. It's a Buick Century,1988 four door Custom. It ran fine when I first bought it but found out there were more problems. First whenever I drove like about 10 miles it starts rubbling and stalled. I go to start it up again and it does start and goes into N/and Reverse but once I went into drive it stalled again. So I have to let it sit for like a half hour. It only happens for longer distance trips, not in town kind. Then I need how to fix my windows cuz they go down like .0001 mph, but that's probably simple. Then my steering is making noises and i can feel it when i turn on corners. Well thanks for responding, and feel free to ask questions.
Old 11-27-2004, 04:46 PM
public's Avatar
public public is offline
Re: Lots of Problems!!!88'Buick Century
Easy fix. Unplug your TCC Solenoid. This is a very common problem.
Yes, I am retarded.
Old 11-27-2004, 04:50 PM
keep it unplugged? is it needed for anything. and this is for the stalling right?
Old 11-28-2004, 10:06 AM
yogi_123rd yogi_123rd is offline
How to fix your slow windows: The window track has built up dirt over the years causing high resistance. You need to lubricate the tracks, but if you use an oil based lubricant, it will stain.
I recrement using a bottle of RAINX instead to lubricate the tracks. This product is a glass wax in an alcohol base.
Old 11-28-2004, 01:53 PM
i dont know how to unplug the tcc. can someone explain it to me? and thanks for the help with the window problem.
Old 11-28-2004, 04:34 PM
public's Avatar
Yes, the TCC plug is on the tranny towards the front of the car. It is near where the tranny bolts onto the motor. It is the only electrical plug in this area. I believe on this car it has two wires. And yes you can leave it unplugged if it fixes your problem. The TCC Solenoid locks up the torque converter on the highway for better mileage, most people do not notice the loss of MPG and if they do it is small. Good Luck.
Yes, I am retarded.
Old 11-28-2004, 04:35 PM
public's Avatar
As for the steering, check the fluid level.
Yes, I am retarded.
Old 11-28-2004, 08:29 PM
yes the fluid was low and after i filled it up, it worked fine again. i dont know if there's a leak or anything.
Old 11-28-2004, 08:30 PM
also do i have to get under the car, or just under the hood.
Old 11-29-2004, 03:11 PM
bignoisey bignoisey is offline
If your steering fluid is low, check the hydraulic lines from the steering pump to the steering rack for leaks. Also check for leaks around the ends of the rack where the tie rods attach. There will be rubber boots here. Changing hoses is kind of tight work since there is not much room behind the engine to work. Changing the rack is even worse.
Old 04-21-2007, 10:42 AM
mmannery mmannery is offline
I have a 91 Buick Century. Is it the same? I disconnected the plug, but the speedometer is not working now. Is one the wires for that? There is a white and black wire. Can one be cut to prevent the stalling and keep the speedometer working?
Thanks!
Old 04-21-2007, 01:02 PM
maxwedge maxwedge is online now
A990 racer
This thread is 3 years old, please start a new one.
Old 04-22-2007, 01:07 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Good observation Shep. Thread closed.
Timeslip 08/12/06
AF Community Guidelines
Closed Thread
