Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Maintenance
Maintenance problems, fixes.
Old 02-27-2002, 11:08 AM
sonyisdope sonyisdope is offline
Send a message via AIM to sonyisdope
My car won't start
Anyone. . .PLEASE HELP! My car won't start at all. It is a 93.5 G, anyhow, it's been starting really slowly lately, and its not the battery, because everything works fine. The engine just doesn't even turn over anymore. Whats up with that? For christs sake, my car is sitting in my girlfriends driveway, and I have to drive her fucking Escort around today. Please help me.
-Dan
P.S. I'm also selling my G20 if you are interested, and in the Michigan area. he he
Old 02-27-2002, 09:42 PM
paradyme paradyme is offline
Lightbulb
Are you able to turn on your radio or roll down pwr windows. If so this could be your starter or possibly your fuel pump.
:flash:
paradyme
95'G20t/AUTO/BLK
STILLEN HEADER/INTAKE/JWT/ECU/S3 CAMS/P11 99 G20 RIMS/
VIPER SECURITY/w/ REMOTE START/ ALPINE AUDIO
Old 02-28-2002, 07:17 AM
G-Forces's Avatar
G-Forces G-Forces is offline
Banned
When you turn the key does it just make a click click sound? It takes a lot of juice to start a car. I'm thinking it is your battery, but you really haven't described much about the symptoms.
Old 02-28-2002, 03:46 PM
the battery is good
Ok, the battery fires up just fine, like my radio works, all my windows work, and my lights work. When I turn the key, it makes the "click", but after that nothing. The engine doesn't even start to turn over. Anyhow, please help me some more. If it is the starter, how do I replace that? If it is the fuel pump, how do I replace that?
Thanks is advance.
Old 02-28-2002, 04:51 PM
poppy_morenito's Avatar
poppy_morenito poppy_morenito is offline
Send a message via AIM to poppy_morenito Send a message via Yahoo to poppy_morenito
Maybe Altenator .... it sounds like what happened to my car a few months back .... I was luck and my buddy sells them .. came to my job replaced it in the parking lot and I was off ...
You can email or call him:
Andre
305 282 3643 cell #
[email protected]
Good Prices cheaper than dealer ...
93.5 G20
JDM SPEC SR20
JWT POP CHARGER
GROUND CONTROL/KYB ADJUSTABLES
17" VOXX MGR 205/40/17
Old 02-28-2002, 07:03 PM
AznVirus's Avatar
AznVirus AznVirus is offline
Send a message via AIM to AznVirus
maybe possible the starter? its not even cranking?
1.6 - The Underdog
GA16DE-T Club!
Old 03-01-2002, 07:46 PM
nis.k.a.'s Avatar
nis.k.a. nis.k.a. is offline
Tap on the starter with a decent wrench, not hard enough to dent the casing but what you are doing is freeing any carbon build up. After tapping it a couple times (it can be done from the top of the engine) it will start IF THE STARTER IS WHAT'S GIVING YOU THE PROBLEM. It could also be the fuel pump. If you're radio and everything works, I going to say it's not your alternator. Check the starter first. You get the click click...good. Trust me, you don't want to replace an ignition switch.
nightmaR3Z
Old 03-02-2002, 01:40 AM
T4 Primera T4 Primera is offline
Assuming your battery is good enough, then it's your starter. Try the give it a bash trick as mentioned above.
If it was your fuel pump or alternator your engine would still turn over.
"The cause of liberty becomes a mockery if the price to be paid is the
wholesale destruction of those who are to enjoy liberty."
-- Mohandas Karamchand Gandhi
"They that can give up essential liberty to obtain a little temporary safety
deserve neither liberty nor safety."
-- Benjamin Franklin
"The biggest cause of trouble in the world today is that the stupid people are
so sure about things and the intelligent folks are so full of doubts."
-- Bertrand Russell
Old 03-02-2002, 10:26 AM
CanadianG's Avatar
CanadianG CanadianG is offline
Send a message via ICQ to CanadianG Send a message via Yahoo to CanadianG
Here's a thought
have u checked ur terminals to your starter??
U might have a bad ground or a loose one.
Same thing with your positive lead.
If I knew where in Michigan u were I'd pop in and take a look Im in Windsor and am heading over to Deerboarn to go shopping at Fairlaine mall
Women call my bedroom the COCKpit!
Old 03-02-2002, 12:50 PM
got it fixed. . .
Ok, it was the starter. I found a refurbished one at some janky ass local shop, and I installed it yesterday. Everything is ok now, however, my engine idles kinda low, should this concern me?
Old 03-02-2002, 02:50 PM
CanadianG's Avatar
what is a low idle to you?
Old 03-02-2002, 04:58 PM
PatrickG20 PatrickG20 is offline
Re: the battery is good
Thanks is advance.
That's odd. I'm having exactly the same problem right now. No symptoms before this happened. I went to my car, pushed in the pedal, everything works fine, but all I get is a "click". I even double checked the clutch-petal engine stop switch, and pushed it in manually. Made no difference. I went back to the car about two hours later, and it started no problems. I turned the ignition on and off several times, and it started fine except for a slight popping noise just after starting the engine. Then when I got back home again, it stopped working again.
Old 03-03-2002, 01:24 PM
nis.k.a.'s Avatar
This could also be a failing starter problem. When you said push in the pedal, which one were you referring too?
nightmaR3Z
Old 03-03-2002, 02:53 PM
The clutch pedal.
I haven't had a chance to have the car checked yet. I'm hoping its just a dead battery, especially after seeing the price of a new starter. The battery currently in my car is old and due for replacement, so I'll keep my fingers crossed.
Old 03-03-2002, 04:10 PM
Where is the starter located on a P10? The car's sitting in a parking lot, making it hard to get enough light into the engine area, especially since its pretty cluttered.
