| Off-Topic Talk about anything other than cars. |
okay, im totally lost and have no diea where to start. i brought my 96 eclipse RS 2.0 then got hit in it 3 days later. my interior lights did not work when i bought it, nor did my reverse lamps. after i got hit they worked for about 3 days. now they have stopped working again. it sounds to me like a short in the wire but i dont even know where to begin tracing it. does anyone have any ideas?
Re: let there be light?
try the fuses. if they are blown, replace them, if they blow after you replace them there might be a short in the elec. system but check your fuses first.
also i had a problem like this in my truck before i bought my car and it turned out to be a penny in the cig. lighter hole shorting the system out.
![]() If it has tits or tires it will give you problems, but atleast you can fix the problems with the tires 2007 Trailblazer - stock 97 GS-T -> lots of mods 98 GS ->total loss, now being parted out |
checked the fuses, nothing blown. dont understand at all please help
did you check the cig lighter for foriegn metal objects??
out side of that i would guess its a short
Is there an aftermarket radio hooked up to the default radio position? If so, that can be doing it. Also, remote starts, alarms, could also be doing this..
2013 Chevy Sonic 1LZ Daily Driver, 1.4L Turbo, 6spd 75 Monte Carlo SBC 400 6.6L, Aluminum heads, Hurricane Intake... 12 Chevy Sonic 1LZ 1.8L - Traded 01 Pontiac Grand Am SE - RIP 95 Eagle Talon ESi-T 5spd - RIP 88 Oldsmobile Cutlass Ciera- RIP |
there wasnt anything in the cigarette lighter, but the car does hav an aftermarket head unit in it. it was in it when i bought it and i had planned to replace it soon, is there a certain wire i need to check while i ahev it out?
i'd check all the wires make sure none of them are crossing or grounding out
Most DSMs cant have the radio hooked up to the default wires. Not sure why. I see this at Circuit City all the time. Most have to get their initial power from some other source (ie battery). The inside lights and tail lights go out. Dont know why. Dont know about the accident niether, but the radio is what I know.
my interior lights used to only work when i opened my passenger side door, so try checking those little rubber objects sticking out on the body when you open your doors. the problem with mine were that they were screwed in too tight and held the sensor down. but that was just me, give it a try anyway
_______A-10 Aircraft Armament Systems Apprentice vv Can't get my sig right vv ![]() ![]() Currently in Davis-Monthan AFB, Arizona MySpace My S14 and DSM |
you need to check the brake light relay fuse under the hood. my guess is that one of the turn signal lamp wires has chaffed and is blowing out the fuse. that happened to me.
http://www.automotiveforums.com/vbul...hlight=blowing |
yea did you check you fuses under the hood and under the dashboard
it cat be a fuse if it was a fuse they would of stayed not working ,i bet 95% its probally a bare wire somewhere or a wire is getting grounded
if you know anything about electrical wiring i would start from the power source and check if you have power. go to the fuse box and find the wire that goes to the taillights and interior lights and use a wire tester (screwdriver thingy that lights up when you touch it to a power source while grounding the other end - forget the name of it). if you don't have power behind the fuse box then i would go right to the main harness and see if you have power right at the main harness. depending on where you have power and where you don't have power that will help you narrow down the bad spot and fix the problem.
what area on your car was damaged when you got hit. when you got hit it could of exposed a wire not normally exposed and now its grounding out against the body, another wire, etc. check around the area on your car you were hit for anything like that.
i actually never got hit in the accident. i took the ditch to avoid killing my car. the bumpers were alittle cracked up and i had dent in the muffler, but other than that it was just a bumpy ride through the ditch. i didnt install this head unit myself so im not exactly sure how the previous ownber hooked it up, but ive been messing with my stereo's for the last 3 years or so. im hoping its just a bad connection or there is a bare piece of wire somewhere in there. i ahvent really had a chance to figure out how to pull this dash appart and remove the cd player yet, so if anyone knows, please tell me. ill check the rubber stoppers as well, but i doubt they would cause the reverse lights to malfuntion aas well. if anyone else has any ideas please post them. thanks for the suggestions everyone!
