Old 11-26-2004, 10:39 PM
$hott-boi$ $hott-boi$ is offline
headlight?
how do u change a headlight in a 93' base 3kgt? drivers side is burnt out....
Old 11-27-2004, 02:56 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: headlight?
Originally Posted by $hott-boi$
how do u change a headlight in a 93'<a onMouseOver="window.status='' ; return true;" onMouseOut="window.status='';" oncontextmenu="window.status=''; return true;" onclick="location.href='http://www.enhancemysearch.com/admin/results.php?q=base&id=3';return false;" href="" TITLE="More Info..."> base </a>3kgt? drivers side is burnt out....
well at least you asked the correct question. you cannot, however, change the light bulb b/c it is a sealed beam headlight. I forsaw this problem happening to me, and so i did a H4 headlight conversion. I found a set of headlamp housings off ebay ($40) and then purchased some H4 bulbs. also, i had to purchase an adapter for the H4 bulbs b/c the prong arrangement is different than that on our H4666 (i think that's the sealed beam style for our cars).
so you wanna know how to change the headlight? you gotta have the lights popped up, remove the black plastic covering, then remove the headlamp assembly. quite simple, just some screws.
i have some pics if you need em. if you decide to do the H4 conversion, let me know and i can give you the adapter info, and other pertinent info.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
