| Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems. |
which turbo v8 setup to go with?
alright guys i have a choice of going with a stroked 302 ford small block; 347 or a chevy 350. which do you guys think would be better for turbocharging? either engine will be built to handle around 10 psi, turbo cam, around 200 cc aluminum heads, the works. i am taking my time on this project and everything will be built right. the set up will be carbed though which most turbo guys will hate. i only want one boost setting so it should be done once i get the air/fuel dialed in. I am not going for multi stage boost or a hi/lo controller so i believe the carb will be the most cost effective set up for me. just really wondering what my fellow AF guys would recomend for the block?
Re: which turbo v8 setup to go with?
ford 351 cleveland, has the best smallblock heads available. aftermarket or stock.
Re: Re: which turbo v8 setup to go with?
With the 351C if you raise the exhaust ports you'll gain about 75HP without doing any other thing to the engine. I used a 351C to set the world record on the Salt Flats. Don't even know if it still stands. |
I agree, if you can fit the 429/460 in your application(what is it?), by all means do that. It can handle much more power and require less boost to get there, has basically enlarged 351c 2v heads. Plus they're cheaper(more common) and parts are easier to find.
It is going in a 85 rx7. whatever i put in will have to bolt up tp 302 motor mounts or chevy 350 mounts.
351c then. It'll bolt to 302 motor mounts and a 302 bellhousing. Depending on what trans you are going to use, it may need a different flywheel/flexplate. Nothing that you can't get easy though.
I am probaly going to go with a AOD. i need the overdrive to get the top end i want. i was wondering about block strength. how much power can these handle 351 clevlands handle? i have read alot on the 302's and the turbo guys at turbomustangs are cracking blocks left and right it seems like!
I'll do some more looking into this tomorrow then. zgringo always on time with some good advice. i think you may have just made me a ford guy for a while.
are these engines any taller than the 302's? or wider? space with me is a big issue because of the car i am putting it in i want it to keep a almost stock exterior. I almost want to build two of these cars. one with a 5 speed. fuel injection, 5.0, full interior for daily driving, and another boosted 351c , built AOD. and stripped for a dragstrip delight. life is good!
i was talking to a friend about this the other day. never really have understood the hardblok theory. this is where you fill up you water jackets right? i would think this would kill your cooling system. is this for drag only cars?
The heads are by far the most important part of the cooling system, not the block. If you have an oil cooler, the oil will provide enough cooling for the block. The reasons to leave 1-2" unfilled is to allow coolant to circulate through the head as was intended, plus the top of the cylinder is going to see the most heat for the longest ammount of time... the further down the bore you travel, the less time the cylinder wall sees the flame, and the cooler the flame is. I know several people running blocks filled like this. Think about it - the cleveland has a 3.5" stroke, and water jackets that extend 5.5" below the deck... 2 inches beyond what the flame will ever reach. Even if you just fill it 2 inches, 3.5" of unsupported cylinder wall is much more stable than 5.5" at very little loss, if any, of cooling capacity. I'll probably fill mine to 1.75" below the deck and run a reverse cooling system, through the heads first, then whats left of the block.
No its not for drag only cars. Mine will be 95% street. As long as you have a good radiator and a good oil cooler, you should be fine. |
Stroked 302. Dart aluminum block, Kryptonite crank, forged rods/pistons. AFR 205s, your fav intake (Holley systemax is nice) FTI turbo cam. Then hold on
1993 Mustang GT Blue/Titanium 2tone, 5spd, 3.55s, JBA ceramic shorties, catted H-pipe, dumped Magnaflows, MSD goodies, FMS alum rad, Pro50, balanced/blueprinted forged 327 stroker (8.2 compression), AFR 185s, Performer RPM, 70mm TB, FTI custom cam, SFC, In-floor Subframes, Maximum Motorsports Torque Arm and Panhard Bar, H&R Springs, Bilsteins, MM CC plates, 5 Lug Conversion w/ Silver Bullitts. Full accessories including smog legal. 310rwhp 351rwtq Dyno Dynamics Dyno. Soon to be supercharged |
this is a little off topic but do you still have the rotory, does it still run, and are you trying to get rid of it? feel free to pm me.
Cars are like music. If it ain't fast it ain't shit. |
rear mount turbo (STS) is the best way for v8's.
