Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 11-26-2004, 09:49 PM
azdoublebeck azdoublebeck is offline
Question 86 chevy caprice classic
need to know #1 pug on distruber to start firing order for wires. nothing was marked or replaced when taking on project. any infomation about why car won't start would be helpful. started running sluggish & stalling. would do good on a highway stretch, but stop and go wouldn't cut it. trying to replace wires & plugs. but can't get placed properly to try and start car.
Old 11-27-2004, 02:30 PM
TommySS TommySS is offline
Re: 86 chevy caprice classic
V8 or 6?
Old 11-27-2004, 06:28 PM
Re: Re: 86 chevy caprice classic
Originally Posted by TommySS
V8 or 6?
a v8. think it's figured out but it's not firing right. seems to be backing into the carburator....
Old 11-28-2004, 04:05 PM
Should be straight out to the back of the carb. The firing order is cast into the intake manifold (if it's stock).
Should be 1 8 4 3 6 5 7 2
Old 11-28-2004, 07:03 PM
have the fireing order, have the timing on the mark apparently, there's not a strong enough spark. can't seem to get the spark strong enough to get started...
Old 11-29-2004, 07:10 PM
Be sure to have a fully charged battery on hand, and check the coil connection(s). Sometimes, the coil ends get bent up and it only appears you're connected.
Even if the coil screws penetrated the cap, it should at least "try" to start.
Let us know how it goes
Old 12-03-2004, 11:23 PM
there was not enough spark to fire up. had coil tested. tested bad. bought a new one. car is trying to turn over but still not a full start. but more of a possibility than before...not sure of a next step...
Old 12-05-2004, 03:52 PM
carb flooded?
Spark plugs fuel fouled?
Old 12-05-2004, 04:31 PM
carb flooded?
discovered that the oil is full of gas. dropping the oil pan now and changing oil. from there i'm guessing to start with basics and verify they're all working adequately.
Old 12-06-2004, 08:11 PM
All you need to do is drain the oil/change the filter and refill.
You need to pull all the plugs (at once), and hold the throttle open and crank for about 20 seconds (clear out the raw gas from the cylinders).
Either clean or replace (I'd replace) the spark plugs.
Button everything up and hit the key.
