| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
egr block off plate
anyone know where i can get a egr block off plate, i used to have it saved on my comp but i cant find it anymore, i did a google search and the only things i got was some odd site's that i would buy gum from. Thanks
![]() Bottles are for babies - Real men get blown!!! Car pics 97 eclipse rs - Sold 99 eclipse gs - Blown Motor 97 eclipse gs-t - For Sale 98-99 eclipse gs-x - ![]() - Looking for one
nm find a site, if you guys need to know the site here it is for when someone needs to find one for 14 bucks.
Re: egr block off plate
If this is a daily driver, I wouldn't do the EGR block-off mod. Do some reading up about it.
![]() 95 GSX DSMlink, "50 Trim", and track times coming VERY SOON!
Re: Re: egr block off plate
I think dejon also sells the block off plates for a decent price.
Kevin Jewer RWD Talon - 7.92 at 180 Mightymax - 10.7 at 125 |
Make your own block off plate!! Very easy to do!! I made my own block off plates by traceing the EGR valve gasket and EGR tube gasket, and cutting them out of aluminum and using the bench grinder to clean them up. You need to make two plates, one for the EGR valve on the block and the other for the EGR tube on the intake manifold. Use your original gaskets. Remove your EGR valve, EGR tube, and vacuum solenoid connected to EGR valve and the line running to your intake. Block the nipple comeing out of the intake manifold with anything you can find. You will now have a custom EGR block off plate the works perfect. Removing EGR valve will trigger a check engine light though.
