Old 11-26-2004, 10:22 PM
97GSTspyder's Avatar
97GSTspyder 97GSTspyder is offline
Send a message via AIM to 97GSTspyder
Question can anyone help me with these two questions?
i always forget to ask this question....what is the normal operating temperature of a 4g63? my water temp gauge reads 200 - 210F when my car is completely warmed up...is that normal?
also...i notice sometimes when i'm coming up to a stop, put the clutch in, and stick it in first (with the clutch still in), my car kind of stutters...the rpm's stay still at around 1k, but it feels like the car is jerking a bit...you know what it feels like when your car lurches on a stall? kind of feels like it's doing that...what could that be?
Old 11-26-2004, 10:26 PM
97dsmeclipse's Avatar
97dsmeclipse 97dsmeclipse is offline
Send a message via AIM to 97dsmeclipse
Re: can anyone help me with these two questions?
i pretty shure that temp is normal, because if i remeber right 95gsx racer said that his temp went up to like 210 after he had the big sbr fmic put on and he said that it rasied like 2º from stock i think it was.
Bottles are for babies - Real men get blown!!!
Car pics
97 eclipse rs - Sold
99 eclipse gs - Blown Motor
97 eclipse gs-t - For Sale
98-99 eclipse gs-x - - Looking for one
Old 11-26-2004, 11:00 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
thats sounds like normal temp.
as for the clutch it sounds like your clutch isnt releasing completly. does the car pull forward at all? check your clutch fluid.
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 11-27-2004, 03:42 AM
anarchy1114's Avatar
anarchy1114 anarchy1114 is offline
Send a message via AIM to anarchy1114 Send a message via MSN to anarchy1114 Send a message via Yahoo to anarchy1114
you may just need to adjust your clutch. my gs was doin that and after i adjusted the clutch it ran alot smoother... just my
If it has tits or tires it will give you problems, but atleast you can fix the problems with the tires
2007 Trailblazer - stock
97 GS-T -> lots of mods
98 GS ->total loss, now being parted out
Old 11-27-2004, 03:53 AM
coolguycooz coolguycooz is offline
yeah when you have it in first gear with the clutch in all the way. your clutch isnt disingaging all the way.
Old 11-27-2004, 06:55 PM
i figured if the clutch wasn't disengaging completely, my rpms would drop off some, but they dont...i do need a new slave cylinder and i'll try adjusting it
thanks for the help
Old 11-27-2004, 07:42 PM
how new is your clutch master cylinder. most of the time if your slave is going so is the master. that could be part of the problem as well.
Old 11-27-2004, 11:00 PM
master and slave were both replaced at the same time, around 20,000miles ago or so...
Old 11-28-2004, 05:21 AM
check both the master and slave again just to make sure they aren't leaking. top of the clutch resiveor (sp?) and adjust the clutch. that should take care of it.
