Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 11-26-2004, 08:47 PM
Israel T Israel T is offline
Send a message via AIM to Israel T Send a message via Yahoo to Israel T
Angry stalling
HELP!! My '92 caprice classic keeps stalling on me!
It revs up then back down like it's "gasping" 4 air,then dies on me! I've changed 1)oxygen sensor 2)coolant temp.sensor 3)E.G.R.valve 4)E.G.R. solenoid 5)thermostat 6)map-sensor 7)throttle position sensor 8)air control valve 9)fuel filter. and it keeps stalling on me!! I hear air from underneath the car. could it be the cat.converter? took it to the mechanic and they told me it wuz the distributer and fuel pump. Had it replaced and still it kept stalling!! I wuz out $200+dollars. I'm afraid 2 take it 2 the shop cause they might take me 4 a "ride" again! SOMEONE SAVE ME! I'VE BEEN HAVIN THIS PROB. SINCE LAST WINTER AND IT'S DRIVING ME NUTS! HELP ME KEEP MY SANITY!!!!!!!!!!!
Old 11-27-2004, 02:32 PM
TommySS TommySS is offline
Re: stalling
Does it have TBI (kinda like a carb) or is it direct injected?
Old 11-28-2004, 01:02 PM
HLandin's Avatar
HLandin HLandin is offline
Re: Re: stalling
If its a '92, it should still have TBI. Didn't go to multi-port injection till LT1 in '94.
Old 11-28-2004, 04:04 PM
Re: stalling
Chances are the throttle body is loose and letting in way too much air. My carb'd unit did the same thing you describe
Old 11-28-2004, 07:00 PM
CD Smalley CD Smalley is offline
Re: stalling
Rather than the TBI unit being loose, which is close, it's probably the gasket between the TBI unit and the intake manifold. I bet the piece of the gasket that runs between the two bores is gone.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 11-29-2004, 07:11 PM
Re: stalling
Yeah - that's what I meant to say.
Old 11-30-2004, 06:05 AM
Re: stalling
The revving up and down could indicate a low fuel pressure as well in my experience.... Might want to check that as well.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Old 08-11-2005, 05:24 PM
92CC 92CC is offline
Send a message via Yahoo to 92CC
Re: stalling
HI, my 92 caprice just started doing the same thing today. I just got the car less than 5 days ago . I'm thinking it is the fuel pump, we have alot of those problems in our patrol car as well (crown victoria) the dealer usaully changes the fuel pump and it works for a while but we hav not been able to narrow it down yet.
Old 08-11-2005, 05:30 PM
Re: stalling
Another thing is I change the cap, rotor , wires and spark plugs it helped somewhat but the problem was still there, but it help the rough idle.
Old 08-12-2005, 12:19 AM
burnM's Avatar
burnM burnM is offline
Re: stalling
Mine did the same thing a while back and it turned out to be the IAC valve, but you say that you've changed yours...
I would agree with the others, though and say it it's a vacuum leak somewhere. The base gasket of the TB, or maybe the air horn is warped or loose. Try tightening the the TB bolts, and check the intake bolts too. Or it could just be a really bad vacuum line somewhere.
I have a quirk with the gear selector on my '91... It is very loose (understandable with 300,000 on it) and has trouble staying at the top of park. Sometimes it'll surge while idling if the selector isn't all the way up. As soon as I push up on the selector, it'll even out and idle smoothly. I'm going to be changing out the column with the one from my parts car, so it's not that big of a concern for me. But that could be another possibility (chances are that it's not though).
Just tossing some ideas at you, let us know what you find.
Has anyone checked the injectors?
1977 GMC Jimmy - daily driver-sitting on 33's and bedliner inside and out
1995 9C1 Caprice - winter beater
1994 Impala SS - newest project
1991 9C1 Caprice - (rip)
"There are two great problems in the world today; an ever-growing lack of common sense, and too many warning labels. Take away all of the warning labels and the problem will work itself out..." -B
