Old 11-26-2004, 08:11 PM
maxassassin's Avatar
maxassassin maxassassin is offline
Send a message via AIM to maxassassin Send a message via MSN to maxassassin
Question bottom strut bolts seezed up
what woudl anyoen reccomend to get them off
Old 11-26-2004, 08:37 PM
crx91's Avatar
crx91 crx91 is offline
Re: bottom strut bolts seezed up
get some pb blaster.or get a torch and heat them up.its better if u use air tools.
Old 11-26-2004, 10:52 PM
heat it up will that kidna loosen it up or what
Old 11-27-2004, 03:22 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
Its probly seized to the bushing. Mine did that so I just cut the fork on the strut with a torch, cut the bolt and hammered it out. Then i just bought new bushings and threw them in with the new struts.
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 11-27-2004, 03:54 PM
crx91's Avatar
yes. heta them up cuzz thier seized.use air tools tho.just heat it up around the bolt.let it cool off.then take it off.if ur just gonna take the springs out than u can just take the whole lower controll arm off and than take off the nutts off on the top of the strut.
Old 11-28-2004, 12:39 PM
BullShifter's Avatar
Re: Re: bottom strut bolts seezed up
no way bolts never seize on Honda's suspension
Like they said it needs to be cut off. Do yourself a favor replace the bolt with a honda part or get grade 8 bolts(or better). Don't go to the hardware store and buy some $0.10 junk, suspension bolts need to be very strong. Most likely you will need a new bushing pressed in/out.
My lower bolts were both seized in the rear LCA's so i ended up replacing both control arms that include all new bushings.
Old 11-28-2004, 02:00 PM
ok acutally i got the botls off jsut alittle rust and such but now i gotta cut the back oens off there on the for good so im gonna cut them off
Old 11-28-2004, 03:12 PM
4G4D Store's Avatar
4G4D Store 4G4D Store is offline
Send a message via ICQ to 4G4D Store Send a message via AIM to 4G4D Store Send a message via MSN to 4G4D Store Send a message via Yahoo to 4G4D Store
Let me know if you need any help, I've lowered lots of car.
1991 Sedan LX Auto (Auto2Manual / MPFI / OBD1 conversions complete)
www.naytontech.com :: youtube.com/naytontech
Old 11-28-2004, 07:39 PM
Hilikus Funkin's Avatar
Hilikus Funkin Hilikus Funkin is offline
Send a message via AIM to Hilikus Funkin
it was hard as hell for me to get them off the first time i took off my suspension, my radius rod bolts were even harder. The best way ive found to get off bolts or nuts is to put in the wrench or ratchet and then hold onto something and use your foot and push with ur foot and pull with ur arms, works everytime for me. Brute Force usually always works.
1991 Honda Civic DX Sedan
Old 11-28-2004, 07:54 PM
well i used basicly extra stregnth wd-40 and leverage to lossen the frotn botls the back ones i sjut cut off
Old 11-29-2004, 01:15 AM
vladlos's Avatar
vladlos vladlos is offline
Send a message via AIM to vladlos
what i did was get pb blaster and.... KAZAAM. evertying went smoothly until i broke the head of a bolt off in the lower control arm bushing where the strut meets in the rear. damn. that was a bitch, i stiill have to find a way to get that broken bolt out....i drilled thru enough of it to get the strut off but its still stuck in the bushing, damn.
Old 11-29-2004, 03:37 AM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
yall peole quit to easy, all the cars I work on I'v only had one bolt sieze up to the point it needed cutting off. You just have to know how to manipulate them.
Old 11-29-2004, 07:04 PM
crx91's Avatar
air chissel.. works good.or replace bushings
Old 11-29-2004, 07:18 PM
fooshman3 fooshman3 is offline
Send a message via AIM to fooshman3
yeah im stuck right now with the car half lowered cuz ive been at college so i cant work on it like i wanna, but my fronts came off easily but with the rear ive tried a combo of pb and like 4 other rust cutters. Those little sob's will just not come off so im probly gonna end up cuttin em or drillin em out. im just gettin new bushings and bolts from honda for like 40 bucks
91 CRX Si
Chrome projector headlights, Clear corners, JDM style wing, GTS Tuner Short ram intake, 5Zigen Catback Exhaust, Random Techonology Test Pipe, Neuspeed Short Shifter, Neuspeed lowering springs, Tokico Gas Shocks, Bosch Spark Plugs, Bosch wires, 15" 04 Civic Si wheels, Sony F7700 CD player, Kenwood 6.5" speakers, JBL 12" Subs, SPL 1200W amp
Waiting to go on: DC sports cam gear
Need to buy: oil pan, maybe a mini me swap
Old 11-29-2004, 07:23 PM
crx91's Avatar
try the torch. but the best is just get the whole thing pressed out.dont need to take it off in that case
