Old 11-26-2004, 06:40 PM
Topochicho Topochicho is offline
Send a message via Yahoo to Topochicho
1994 engine swap Possible?
We have a current '94 Eclipse with a 1.8 non turbo that needs to be swapped with a 2.0 non turbo. Could this possibly be (in any stretch of the imagination) an engine swap? Or as one person put it- is it a CUSTOM everything?
So far, all we know is that the computer and harness will need to be replaced, because the '94 computer won't control the 2.0 engine.
But imagening that we can get the computer and harness - is this even a possible swap?
Old 11-26-2004, 06:42 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: 1994 engine swap Possible?
its possible you need a ecu and wiring harness i think you also need the motor mounts
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
