Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 02-27-2002, 08:40 AM
1993HondaCivic 1993HondaCivic is offline
WHY are koni yellows better for lowering???
people on this forum always say how tokico's, kyb's and even koni red's are not too good for lowering. but people say koni yellows are better for lowering. has anyone ever asked why? guys at the shop i go to say tokicos are fine for lowering. to me, it seems that the koni red and koni yellow are the same except the yellow is height adjustable and may be a little stiffer or something. the two shocks are both the same lenght so wouldnt that mean that they both have the same travel range, whether they are used on a lowered car or not. can someone clear this up
thanks
Old 02-27-2002, 01:11 PM
buh_buh's Avatar
buh_buh buh_buh is offline
Send a message via ICQ to buh_buh
I don't know if any of these struts are better or worse for lowering, but I think its just all a matter of ride comfort and personal preference. Koni Yellows have an awesome ride, and that is what I would prefer.
AF Nordic Crew #3
Old 02-27-2002, 05:25 PM
CivicSiRacer's Avatar
CivicSiRacer CivicSiRacer is offline
Civic Mod
Send a message via ICQ to CivicSiRacer Send a message via AIM to CivicSiRacer
Koni Yellows are better cause they can handle the higher spring rates of coilovers. I had Skunkworks coilovers on Tokico Illumiunas and the shocks blew in a year. The Konis are valved more aggresively to handle the higher spring rates.
Sponsored by: KAM Racing Sports, Falken Tires, Finish First Polish, Brady's High Performance, Taggart Performance Engineering, Rotora Brakes
Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO!
Autocross Help Page
Buy my Civic parts!
Old 03-05-2002, 07:22 AM
j.fuggi's Avatar
j.fuggi j.fuggi is offline
i've got illumina's and i have had neuspeed race springs on them now. its been fine so far. i'm getting ground control coilovers. will i have any problems you think?
» Supercharged 2006 Honda Civic Si Coupe
» Info | Teaser Video | Dyno Video | Dyno Graph
Old 03-05-2002, 07:56 PM
-=Evol90Accord=- -=Evol90Accord=- is offline
this may sound like a dumb question
but how is the ride with koni yellows and gc coilovers vs say... stock? believe it or not, of all the lowered cars ive ridden in, none of em were done very well and they all were stiff, bouncy or just hard to ride in.
I just want to know what to expect if I get koni yellows, cuz my ride sucks with stock struts. its not bouncy, its just really stiff (as in a block of cement would prolly do better for ride comfort).
its a lowered family sedan... how fast could it possibly go??
Old 03-05-2002, 08:37 PM
toolowintegra toolowintegra is offline
a block of cement eh? hahah, well if you want a comfortable ride then lowering should not be on your 'to do' list, cuz any way you do it it's be more stiff than stock, you'll have less shock travel distance, it's just the science of the game
---1996 Black Acura Integra----
Integra Type R Front Lip Spoiler
Autometer 5" SportComp Silver Tach w/Lite
Autometer Full dual pod pillar with A/F and Water Temp. Gauges
5Zigen Fireball Exhaust
AEM Cold Air Intake
DC Sports 4-2-1 Header
Eibach Sportlines
Tokico Blue Shocks
DC Sports Short Shifter
Strut Tower Bar
Titinium ITR Knob
98+ OEM taillights
Momo Pedals
Sony 700 Series CD/MD
shipping.... WW RS sides and rear
Old 03-05-2002, 09:07 PM
drift's Avatar
drift drift is offline
Send a message via AIM to drift
proper lowering of a vehicle includes shortened piston struts.. which feature close to oem piston travel.
Old 03-06-2002, 12:37 AM
hate to say it, but the reason i lowered my car was for looks, not comfort (or performance for that matter). I would like the best of both worlds, hence the reason for asking the question.
and maybe a block of cement is a little extreme. Maybe just a hard piece of wood
Old 03-12-2002, 01:57 PM
super 96 accord's Avatar
super 96 accord super 96 accord is offline
I have ground controls on tokico illuminas (I think that's the 5way) for about two years now. I think my front shocks are finally giving on me. They squeak like crazy sometimes. But the ride is still good though.
Old 03-13-2002, 11:31 AM
Dezoris Dezoris is offline
Mod for life
Send a message via AIM to Dezoris
Like CivicSiRacer stated, and to add to it, you lowering springs that offer drops over 2.5" are almost always race springs, race springs have higher springs rates, which means it takes more load to compress. The Koni is the premiere out of the box shock for this, for any type of really agressive spring and lowering, followed by IMO the Bilstein Sport and the KYB AGX.
What people don't understand about GC or other sleeves is that, when you raise and lower the car with them, you are doing nothing to the spring, all you are doing is moving the shock body up and down, and when you lower the car (move the shock body up) you are reducing the shocks compression stroke, when mated to the wrong shocks, which IMO is almost all of them you are actually decreasing your suspensions effectiveness, and ruining your shock. If you want an adjustable suspension you need a real coilover kit with threaded body shocks designed to compensate for lowering or decreasing travel.
If your goal is just to slam your car just use your stock shocks it will be cheaper and hopefully you will blow them so you will ride on all spring
Another issue is saftey, faulty dampers can cause dangerous handling conditions when you have to slam on the brakes or even make an emergency manuver.
Get it?
M.Sanew - AutomotiveArticles.com
Old 06-11-2002, 01:53 AM
OG20's Avatar
OG20 OG20 is offline
what are good spring rates that balance well with koni yellows set rate of compression?
Old 06-11-2002, 11:54 AM
92 Teg-B18A's Avatar
92 Teg-B18A 92 Teg-B18A is offline
I've heard GC makes a set of adjustable coilovers specifically designed to be used with Koni Yellows
92 Acura Integra RS
B18A is the bizzam
PH refugee
AF Nordic Crew #004
Warning: The Surgeon General says it's OK to smoke V-8's.
Old 06-11-2002, 01:24 PM
Civic Mod
No they just send you adapters to fit the GC coilovers on Koni Yellows. Konis are thinner in diameter than most aftermarket shocks.
Autocross Help Page
Buy my Civic parts!
Old 06-17-2002, 01:40 AM
RedRocketGSR's Avatar
RedRocketGSR RedRocketGSR is offline
Send a message via AIM to RedRocketGSR
Ok..i got a question too....Do the Koni Yellows work with any coilover or do they only work for specific ones? Thanks for the info.
95 Integra GS-R
[email protected]
Old 06-17-2002, 07:24 AM
Civic Mod
They should work with any spring or coilover - just make sure when ordering Konis you mention what spring you are using it for.
Autocross Help Page
Buy my Civic parts!
