Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 02-27-2002, 08:36 AM
1993HondaCivic 1993HondaCivic is offline
Which camber kit?
my car's lowered 2.25 in front and 2'' in back. do i need to get "-3/4° to +1°" or the "+1.25° to 3°". just a little confused. when they say the adjustment range of a camber kit, do they mean it can adjust ur current setup that much, or they can make your camber degrees anywhere between the range given? thanks
Old 02-27-2002, 01:47 PM
DemonicAccord's Avatar
DemonicAccord DemonicAccord is offline
Send a message via AIM to DemonicAccord
it depends, some are static some are adjustable. with a drop that low I would strongly recommend a up-to-3deg kit. check out www.ingallseng.com and specprod.com some ingalls and some specprods are adjustable by as little as a 1/4 at a time, depending on the app
Old 02-27-2002, 01:48 PM
www.specprod.com
