I've run into a problem with my '00 Sonoma. It died on the highway last week. It has spark, smell like it has fuel, new battery, good cap/rotar/plugs, all fuses seem to be in good order. It just won't start. Has anybody heard of this problem or have suggestions on what might be wrong? Any help would be greatly appreciated.
Thanks, Darren |
Re: 2000 Sonoma won't run
Check your coil and your ignition module.
![]() ![]() 95 s10 Blazer, EGR Mod, ZQ8 Steering box mod, 99 Center console shifter mod and more... See everything at www.pghconsulting.net/teal |
I had the exact symptoms with my 00 Sonoma a couple of months back (right down to "died on the highway"). It turned out to be the fuel pump.
The dealer wanted almost $1000 to do the work (the fuel pump/sending unit alone was over $600), and an independent shop wanted about $800 (they had to get the fuel pump from the dealership ). I ended up shopping around and found an aftermarket fuel pump for a little more than $300, and I had my brother do the work for me (not an easy job - he'll get a nice xmas present this year ).If it does turn out to be your fuel pump, a word of caution: 2000 Sonomas came in both a standard and flexible fuel version. If you've got a plastic gas tank, your truck is flex fuel. It should also be noted inside the gas door. The flex fuel version used a different fuel pump/sending unit than the standard version, and is a bit harder to find. I found this out the hard way, as I originally bought a pump for the standard fuel version. I bought mine at a Murray's Auto Store here in the Detroit area. For your sake, I hope it's not the fuel pump. Good luck! |
