Old 11-26-2004, 11:50 AM
92VR4Red's Avatar
92VR4Red 92VR4Red is offline
Question Cheap Front Mount Kit???
does anyone knpw where i can find a cheap front mount kit?..
i knwo its hard... i dont have 1500 dallors to spend...
Upgrades... To many to list...
Old 11-26-2004, 01:24 PM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
Re: Cheap Front Mount Kit???
1500 is about as cheep as they get, you could buy a welder and a FMIC from a large truck and make your own.
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
Old 11-29-2004, 08:31 PM
X3000's Avatar
X3000 X3000 is offline
What about the front mounts on E-bay? They look pretty good I was thinking the OBX one is that any good?
"96" 3000GT SL
Neon Night Rider
(R.I.P.) 2003
"94" 3000GT VR-4
New Neon Night Rider
Best time 12.9@104mph Mods:K&N,BOV,Test Pipe,MBC@15 psi,Downpipe,gutted precats
Old 11-29-2004, 08:34 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
With ebay stuff theres a good chance of it not fitting correctally, mostly its just the cores on ebay so you would have to fab all the piping. Pluss the cores probably aren't great quality so it might not be worth it.
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 11-29-2004, 09:02 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
check out this site: http://www.geocities.com/speedpartsrus/3000gt.html . they have some pretty cheap, though apparently quality-made intercoolers. however, it says they are out of stock, but i would e-mail them to see what options you might have on getting one.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 11-30-2004, 12:06 AM
Ive got the 14" kit off that site.
Old 11-30-2004, 12:25 PM
aorozco2's Avatar
aorozco2 aorozco2 is offline
Re: Re: Cheap Front Mount Kit???
that's right 1500 is about as cheap as they get, but not if you are trying to buy a used one. On ebay for example.
Old 11-30-2004, 09:30 PM
Igovert500's Avatar
blue + red light magnet
Thread on 3si about ebay intercoolers...you might want to check out:
http://www.3si.org/forum/showthread.php?t=244946
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
