Old 11-26-2004, 11:58 AM
comocozzy2 comocozzy2 is offline
idle problems
hello all well to be honest i new to all this so i wanted to c if i can get some advice. i have an 88 honda civic lx 1.5. the isle is completly screwd
up. itidle eather to fast or to slow. I have already changed the spark plugs im gonna also change the sp wires and the oxygen sensor. I took a look at the pcv valve today after l;ookin for it for so long. the was alot of black sooty stuff inside the hose that connectes tothe valve i change the valve but used the same hose it doesent look like a tight fited seal like before i tryed to remove some of the build up.anyways what can u recommend as far as the idle. i have aleady replaced the idle speed control valve aswell......
Old 11-26-2004, 12:10 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
Re: idle problems
check your vacuum hoses and then the throttle postion sensor.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 11-26-2004, 06:11 PM
Hybrid1990crx's Avatar
Re: idle problems
TPS is on the back of the throttle body in case you dont know.
Old 12-03-2004, 01:37 PM
kcjames19 kcjames19 is offline
Re: idle problems
I Have the same problem in my 91 civic Lx, after i swap a ZC motor in it..
either idles at 400 of 1200... oh and now it wont start be cause i ajust it to low and my check light is on...YA YA i allready tryed put it back to normall it didnt work
Old 12-03-2004, 03:17 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: idle problems
ok try play with the idle screw, turn it up and down just alittle and see if that works, if not check all vacuum hoses for leaks, pull of iacv sensor plug and see if this stablizes the idle, if it does you need to clean the iacv by taking it off and spraying that little screen with carb cleaner. if it doesnt then take off your intake and look on the tb theres 2 holes, plug the bottom hole and see if that stablizes your idle, if it does you need to take off the fitv and screw the center back in
Team Lonely Drivers
