Go Back   Automotive Forums Car Chat > Oldsmobile > Ninety Eight
Old 11-26-2004, 09:55 AM
NJSoundguy NJSoundguy is offline
Question Problem with my 88 Ninety Eight Olds
Hello Everyone,
I have a problem. There is this unit right next to the radiator (drivers side). After I turn the car off, this unit is still running. I think it might be an air compressor for the vacum system but don't know enough about it. I had to electricly disconnect it so not to run battery dead.
If anyone know why this unit stays on, any help would be greatly appreciated. It just started happening yesterday.
Thank you in advance
Dean
Old 11-27-2004, 12:12 AM
mrrob mrrob is offline
Air Compressor for Rear Suspension
It sound's like the air compressor for the rear suspension, you probably have a leak in the system, and it's constantly trying to re-fill the rear shocks.
Hope this helps
Mr.Rob
Lic Mech Auto/Truck/Trailer Ect...
Old 11-30-2004, 12:19 PM
Hansnet's Avatar
Hansnet Hansnet is offline
Re: Problem with my 88 Ninety Eight Olds
he is right. it is part of the elc - the leveling suspension option. You probably have shot struts back there and there is an air leak either on the connector or the strut itself. This is a very common problem for struts to leak. Just replace the rear struts and you should be fine.
Old 12-07-2004, 11:09 PM
Thompjer Thompjer is offline
Send a message via AIM to Thompjer Send a message via Yahoo to Thompjer
rear struts
Beautiful! Thanks, I was having the same problem!
Old 12-07-2004, 11:39 PM
I have Seen!
I have also had cars come in and while checking the fuse panel, the fuse for the self-leveling has been removed, I guess the car owners found replacing the struts to expensive, and just pulled the fuse.!
So the choice is yours cheap fix or the right fix!
Mr.Rob
Lic Mech Auto/Truck/Trailer Ect...!
Old 12-08-2004, 11:38 AM
Re: I have Seen!
Mr. Rob, you sound like a knowledgable kinda guy, I just bought a 92 98 and I'm trying to find the Data Link Connector. Any clues as to where it is and how I use a jumoer wire? MUCH appreciated.
Mr.Rob
