Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-26-2004, 04:32 AM
chairfan chairfan is offline
Send a message via ICQ to chairfan
Oil leak....NEED help!!!
I have a 95 Eagle Talon ESI and I need some help resolving my oil leak problem here.
If you run my car hard it will leak and if you take it easy it holds oil rather well. But lately it's been getting worse. Yesterday I changed my oil, oil filter and as well as valve cover gasket today. But there is still a leak coming from underneath the car, about a drop every 10 seconds. I checked my oil filter for leaks and it was fine. There is nothing else wrong with the car just an oil leak... So where might this oil be coming from, or what do you suggest I do to find out?
Old 11-26-2004, 10:38 AM
riff22 riff22 is offline
Re: Oil leak....NEED help!!!
might be the gasket on your oil pan. or check your drain bolt make sure its tight.
Old 11-26-2004, 02:44 PM
Do I have to pull the motor to change it?
Old 11-26-2004, 04:37 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
no.
DSM geek
Old 11-26-2004, 06:05 PM
There is a crossmember that the oil pan rests on how do I go about taking care of that?
Old 12-03-2004, 12:12 AM
coolguycooz coolguycooz is offline
I dont think you need to remove the cross member to replace it do you? You can just unscrew it and slide it out but if you have to remove it. Take a block of wood put it under the oil pan and jack it up to where you can feel that the jack is holding some of the weight. Then just take off the crossmember. I dont recommend doing it this way if you have a turbo because of the CW issue. The whole bending/denting your oil pan thing. Not sure if it will in the haynes manual it says to do the block thing.
