Old 11-25-2004, 11:29 PM
JeepWoman JeepWoman is offline
Post 92 Jeep redo Comfortride Shifting problem
HELP!!!! Need info on shifting problem with automatic 2 wheel drive. Will not shift into "Overdrive"- any help is most appreciated.
Old 11-26-2004, 11:01 AM
Saudade's Avatar
Saudade Saudade is offline
Re: 92 Jeep redo Comfortride Shifting problem
Have you checked your transmission fluid level? If good, change the fluid and tranission screen.
Also, make sure your shift lever is in the "D" position. A poorly adjusted linkage can put your tranny in 3 when you think it's in D.
Old 11-27-2004, 04:15 AM
Thumbs up Re: Re: 92 Jeep redo Comfortride Shifting problem
Thank you, will definitely check tomorrow.
