[font=times new roman][size=7][b][i]
2000 Siverado 1500 LS How do I remove the drivers side door panel to fix the speaker that has fallen out? Thank You Garry Muir |
Re: Door Speaker
If you have power windows pop off the door console that has the lock and window switches in it. Use a flat blade screw driver and gently pry it up. Unplug the wires and put to the side. Remove the screw that is exposed after you remove that piece.
Now remove the screw right under the door handle. Once both screws are out grab the door panel and lift it up and off the door. You will need to unplug the wire to the tweeter and the door light. You should now see the speaker. Carefully peel back the plastic to get to the speaker. The plastic is glued down around the edges. Do the reverse of above to reinstall. Good Luck. MC |
Thank you for your help I will try it now that I know there are no clips to break. Thank You Garry Muir |
Re: Door Speaker
I love the door panels on these trucks. All door panels should be this easy to pop on and off...
![]() I've had mine off a couple of times and the doors themselves aren't that bad for working on the insides. Had to change the door latch assembly on my passenger side. Took me about 40 min total to do the entire job.
2008 GMC ACADIA SLE Edition, 7 passenger model I AM Canadian!! ![]() |
Same here Chuck16. I was surprised at how easily the door panel was to remove. Good thing to know it isn't clipped on because you would destroy it trying to pop out the clips that don't exist.
Took me all of 45 minutes to replace the power window mechanism in my passenger door. MC |
