Go Back   Automotive Forums Car Chat > Racing > Street Racing
Old 11-25-2004, 06:06 PM
musclehead24 musclehead24 is offline
Mitsubishi 3000GT base or VR-4?
Hi I'm new to the boards here and I want to know if I would be better off buying a base Mitsubishi 3000GT and adding a turbo kit or buying the the VR-4 model. Now money is an issue and the VR-4 is more expensive, but it is more powerful. What would be cheaper? Adding a turbo or buying the VR-4?
Old 11-25-2004, 06:14 PM
youngvr4's Avatar
youngvr4 youngvr4 is offline
STREET RACING GURU
Re: Mitsubishi 3000GT base or VR-4?
go to the 3000gt forums and ask this question, this is for street racing.
http://www.automotiveforums.com/vbul...splay.php?f=44
Old 11-25-2004, 06:40 PM
SiGNAL748's Avatar
SiGNAL748 SiGNAL748 is offline
Send a message via AIM to SiGNAL748 Send a message via MSN to SiGNAL748
I believe dishing out the extra for a VR-4 is well worth it. The base and the SL use a frontwheel drivetrain. Even if you were to take a base 3kgt, turbo it, and have it put out the same power as a VR-4, you'd find that it'll be a bit hard to get it all to the ground.
Old 11-25-2004, 07:45 PM
Thnx guys. I didnt know there was a mitsubishi forum.
Old 11-25-2004, 08:09 PM
HighRev87's Avatar
HighRev87 HighRev87 is offline
Banned
I would definitly point to the vr4.
Old 11-25-2004, 08:29 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
Come check out the 3000GT forum, thats the place for you. See you there.
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 11-26-2004, 11:22 AM
PearlGT PearlGT is offline
I used to preach the turbo kit for the base 3000gt's but the vr-4 comes stock twinturbo all wheel drive and that just makes it so much better compared to all the work you'd have to do to a base or sl 3000gt to get it up to that level.
