I was wondering if someone can help me install a block heater for the '96 toyota camry. I checked out the other thread on this subject, but it did not help. i need someone who could help me through an easier way. steps should help. The installation book is kinda difficult. I know which area to put it, but where do i plug it in? well thanks, i will be waiting.
Re: Block Heater on '96 Camry
If I'm not mistaken, you have to plug block heaters into an outlet in the house via an extension cord.
Normally, a block heater is inserted in a freeze plug hole instead of the plug. You drain the coolant, pull a freeze plug that is out of the way and as centrally located as possible. Install the heater in a clean dry hole with sealant, and a hammer with some sort of large socket or pipe that fits the OD of the heater plug. Doing this, you make sure the inside portion doesn't touch anything.
Re: Re: Block Heater on '96 Camry
