Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 11-25-2004, 11:24 AM
ARK51294 ARK51294 is offline
need emergency help.
OK was going to NC from DC. Towing about 4k worth of weight. Blew something. Check engine light flashing. Real rough idle at start slow pick up. No power. Runs like doo. If I am giving it gas It is ok. But it has a real rough idle. Burns gas like it is nothing. Any Help is appreciated. Thanks
Old 11-25-2004, 11:27 AM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
Re: need emergency help.
Clogged or clogging catalytic converter, maybe. Do the key test and see what codes you get.
My Mopars
Old 11-25-2004, 12:00 PM
LTJGWorth's Avatar
LTJGWorth LTJGWorth is offline
Well, if you truck is older than 1997 the key test won't work. I don't think that a clogging cat converter would blow something without some sort of warning before hand. I mean, usually you will notice the lack of power when the cat starts to clog. I wouldn't think it would just clog and blow.
Old 11-25-2004, 12:10 PM
its a 98 quad 1500 5.2 whats a key test
Old 11-25-2004, 01:09 PM
LTJGWorth's Avatar
Never mind about the key test. On 1994 to 1997 models, you can get check engine light codes by turning the key in a sequence, but on 1998 and later models they took that feature off.
Old 11-26-2004, 03:07 PM
Well I didt blow anything. Sparkplug wire was laying the exhaust manifold. All good now. Thanks to autozone for the check engine check
