Old 11-25-2004, 12:09 PM
burntrice087 burntrice087 is offline
Banned
car vibration/shaking
I first noticed my cars handling sucks on the highway the first day i got it....When i go past 60MPH the car shakes violently and its wicked annoying.....Since my tires were pretty much bald..i replaced them and got a 4-wheel alignment......For some reason it still shuddered and shook on the highway......MY shocks/struts were going out too so i got those replaced and got another alignment.......I thought i had finally solcved my problem but as soon as i got onto the highway again...the damn bitch still shakes and virbates at any speed past 60MPH
Old 11-25-2004, 01:42 PM
duplox's Avatar
duplox duplox is offline
Send a message via AIM to duplox
Re: car vibration/shaking
What do you have in the rear end? Open, limited slip, locker, spool?
My '69 had a similar problem, though it happened around 45-50mph. What I did is remove the center section from my 9" and stuck the axle shafts in it without the case. I then turned the yolk over with it bolted to a stand and watched the endplay of the axle shafts. One moved up and down .75". At low speeds, it wasn't enough of a difference to cause a vibration, since the bearings could hold it in place and the shocks could dampen any vibration. Once I got goin fast enough, it would vibrate in pulses... fade in vibration and fade out.. probably 1 'pulse' every second.
Unfortunately, you most likely have an 8.8" axle, which you can't take the center out to test like in a 9". You probably have to take it to a shop and have them run some tests on your differential.
Old 11-25-2004, 03:26 PM
StillGoin5.0 StillGoin5.0 is offline
Send a message via AIM to StillGoin5.0
were your tires properly balanced?
87 5.0 5 spd T-Tops - mass air conversion 9AL, msd distributer, coil, fms 9mm wires, bbk ceramic coated long tubes, bbk h pipe, 3" flowmaster catback, 190 lph fuel pump, 24 psi injectors, 70mm cobra meter, bbk AFPR, bbk fender kit with k&n filter, 12* base timing, flex fan, 3 row aluminum radiator, 6 piece headlight kit w/ clear corners, silver ponys, stormin normin cowl hood, saleen wing, and recently a new heater core
Old 11-26-2004, 11:36 AM
motorjock205's Avatar
motorjock205 motorjock205 is offline
Send a message via MSN to motorjock205
vibration
Might also check your driveshaft to make sure it is not bent....my 96 had a bent driveshaft and I replaced it with an aluminum driveshaft...stopped the vibration in it's tracks.
Forget World Peace, Visualize Using Your Turn Signals!!!
Carl W. Ervin
2008 Shelby GT CSM 08SGT0235
Old 11-26-2004, 11:31 PM
Banned
how much is a driveshaft
Old 11-27-2004, 02:29 AM
Future303 Future303 is offline
I've seen the Aluminum Driveshafts for $100
95 GT AKA "The Purple Hippo". Stock 302 bottom end. Edelbrock Heads. Performer 5.0 Intake, 1.7 RR's on stock Cam, Stock T5, 3.27 gears, UD Pullies, K&N Filter, rubber boot deleted, A/C deleted, BBK Catted X-Pipe, 180º TStat, EEC Tuner running J4J1 stock BIN. AEM WB02, Minor tunes, running pig rich. No clue as to RWHP feels a tad faster than a stock 05 GT.
Old 11-27-2004, 09:09 AM
vibration
Actually, the cheapest I've seen the driveshaft for is about $179.00...but it is money well spent in any case...
Carl W. Ervin
Old 11-27-2004, 02:51 PM
MARS's Avatar
MARS MARS is offline
Re: Re: car vibration/shaking
Good question! Also check out your motor mounts. Had that problem bad in my VW!
Old 11-27-2004, 05:42 PM
cybergomer cybergomer is offline
one thing you should also check is the brake rotors. I had a similar problem and I fixed it by scraping any debris between the rotor and the spindle
Banned
i cant seem to find an aluminum driveshaft for my Mustang....can someplease please give me a website
Old 12-22-2004, 12:02 AM
ChiTownClubHead ChiTownClubHead is offline
Send a message via AIM to ChiTownClubHead
Driveshaft is a good possibility. Check steeda.com for an aluminum driveshaft, or a Ford racing and performance parts store.
Sounds like your ball joints could be shot also. Have them inspected and have new ones installed that are greasable. When I installed new ones on my ride, it was like driving a new car.
One more thing to check, is the motor mounts. Ive replaced mine (both sides) once already, and one is cracked as of now. That would also cause a lot of shaking and vibration.
Old 12-24-2004, 06:10 PM
slick_5.0 slick_5.0 is offline
do u notice a vibration coming from any certain point in the car? i noticed a bad vibration coming from my front right tire at about 60 mph and it shook the whole car. turns out it was the u-joints. might wanna give those a look as well. that was my problem. good luck man
