Old 11-25-2004, 10:23 AM
92VR4Red's Avatar
92VR4Red 92VR4Red is offline
Exclamation Fuel Cut!!!
Ive been geting fuel cut on my car. i replaced the fuel pump just resently and that didnt help all it did was help it quit runing lean :S ... i have my boost controller turned off and still it fuel cuts... but not as quick. my boost tstill wants to climb to almost 25 psi... it cuts around 18-20 psi... i know they make computers to help override it (because its the computer that causes it to fuel cut... when you hit a sertian amount of boost the computer says to cut feul) but they dont make them for vr4s because as i was told "VR4s are know to be some of the few cars that dont ever fuel cut"... anyone know what to do?... i dount it will help but would increaseing the injector size help? i know they came stock with 450cc but mabey if i jump to a 550cc it might help...?
need feed back plz.
Upgrades... To many to list...
Old 11-25-2004, 11:52 AM
BB1970's Avatar
BB1970 BB1970 is offline
Re: Fuel Cut!!!
yes they do cut, it is built into the ecu as a factory setting at around 16-17 psi from memory (dont hold me to that figure) but they definately cut. what turbos you running? if they are the std 9b's you are heading for a full engine rebuild if you are boosting that much. you should never boost over 14 psi with the stock injectors and ancilleries. if your boost controller is off and you are still boosting at 25 psi i'd say you have a boost leak somewhere. get it fixed or you will be in for a very expensive rebuild.with the stock settings and your exhaust and intake taken into account, the maximum you should be boosting should be around peak pressure 12-14psi which should fall back and hold to around 9-10psi.
Also the stock injectors are 360cc not 450.
1993 Mitsubishi GTO Twin Turbo (RHD) NOW SOLD!!!
9b turbos with manual boost valve mod set @14psi
turbo xs type h-rfl blow off valve
blitz dome filter
sachs clutch
completely de-catted
fuel pump voltage rewire mod
ebc redstuff front brake pads
greddy fully automatic turbo timer
now drives a sensible family sedan. A 340hp 1997 mitsubishi evolution IV
Old 11-25-2004, 12:01 PM
Igovert500's Avatar
blue + red light magnet
Re: Fuel Cut!!!
Agreed, if you are boosting anywhere aver 15psi on stock injectors you are asking to screw your car up. You need larger injectors, fuel pump, and A/F controller to handle that, and even then the stock turbos can't produce that much boost.
Upgrade the above mentioned stuff or turn your boost WAY down to where it should be.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 11-25-2004, 12:54 PM
youngvr4's Avatar
youngvr4 youngvr4 is offline
STREET RACING GURU
Re: Fuel Cut!!!
are you going by an aftermarket boost gauge or stock
i'm assuming that its a aftermarket, but it seems that you have a boost leak, aftermarket bov do you?
Old 11-25-2004, 09:04 PM
92VR4Red's Avatar
Re: Fuel Cut!!!
i have all that stuff except injectors. i have a
S-AFC, aftert market boost guage, a walbro 341 fuel pump, and a wideban o2 sensor. And yes i have a HKS BOV. i have no boost leak because i checked very very thoroughly.
i have looked into geting a correctional computer but MVPmotorsports (if anyone happens to know who they are, im good freind with Dusty the owner) told me that vr4s are known not to fuel cut.
Old 11-25-2004, 09:14 PM
92VR4Red's Avatar
Re: Fuel Cut!!!
And ive also made sure my car isnt running lean and not detinateing... so im not looking into a rebuild im not that dumb...
Old 11-25-2004, 09:29 PM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
Re: Fuel Cut!!!
Stock injectors are 360cc, DSM's have 450cc injectors.
So what are your A/F's when you are running 20psi. You may not be detonating now, but when the weather begins to warm up you can say bye bye to the motor.
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
Old 11-25-2004, 09:31 PM
Re: Fuel Cut!!!
also the atr downpipe doesnt get rid of the precats.
Old 11-26-2004, 03:17 AM
BB1970's Avatar
Re: Re: Fuel Cut!!!
without being rude or preaching, you ARE running lean, you've got to be at 25psi on stock injectors, and even for some amazing reason you are not lean, all you are doing is blowing hot air through the turbos after 15psi anyway.an AFC device is exactly what you need to stop fuel cut and if you have that fitted, you should not be cutting unless it is set up wrong or you are RUNNING LEAN.
and for all the other forum users who dont know what AFC means it is short for anti, fuel, cut.
as its getting colder now, your boost will actually rise even higher as the cold air is denser than the warmer air in summer time so you have been warned.
i completely agree with tallskinyguy, all might be well at the moment but continual use at 25psi or anything over 14-15psi in fact and its goodnight vienna. it will be just another fantastic machine at the scrap yard and your days of driving a great car will be over.
blitz dome filter
sachs clutch
Old 11-26-2004, 10:09 AM
92VR4Red's Avatar
Re: Fuel Cut!!!
i gutted the precats... basicully geting rid of them... and im not running 25 psi anymore it cuts around 18 psi. and i do beleive afc means Air/Fuel Controller because that is what it does it controlls how much fuel or air you want into the engine. and a 3000gt is a DSM. DSM means Diamond Star Motor (Hint "Mitsubishi")
Old 11-26-2004, 12:32 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
Re: Fuel Cut!!!
Most people on here that I've talked to think the DSMs are just the talon/laser/eclypse because of the exclusive joint venture plymouth eagle and mitsubishi shared for just that car. Nice avitar by the way, gotta love trigun.
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 11-26-2004, 12:33 PM
Igovert500's Avatar
Re: Fuel Cut!!!
Either way, 18 is still too high, you are correct on AFC's meaning, although I think Brian was simply joking about that...and by definition, a 3000gt is definantly not a DSM, go over to the DSM forum, and any true DSM owner will be happy to tell you the same.
Talon, Laser, Eclipses are DSMs, even the latest gen eclipse doesn't qualify as a DSM. Those have 450cc injectors, VR4s have 3600cc injectors...
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 11-26-2004, 12:37 PM
92VR4Red's Avatar
Re: Fuel Cut!!!
well ive gone to www.dsmtrader.com and they include Evos, 3000gts, laser, talons, and eclipse...
DSMs meaning is Diamond Star Motor which is representing Mitsubishi, and i think most ppl say its just the eclipse and their counter parts because they are the most common. here in texas there is a club dsm and they hapily excepted me with my 3000gt. so i beleive 3000gts are dsms...
Old 11-26-2004, 12:43 PM
92VR4Red's Avatar
Re: Fuel Cut!!!
I Dont doubt yall about the injectors but look at it this way ok. Ive been told that they are 450cc. and when i look for bigger injectors every where i go they start with 550cc for the 3000gt ive never found anyone selling 450cc injectors for a 3000gt... nor have a found 360cc. so i thought well mabey seince they atock thats why that dont sell them... but if i was to go larger it would be the next step so i would want to go 450cc not 550cc...
Old 11-26-2004, 12:54 PM
Thourun's Avatar
Re: Fuel Cut!!!
Ohh well, maybe things are just bigger in Texas .
1995 3000GT VR-4
