Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 11-25-2004, 03:26 AM
varisystarter varisystarter is offline
Send a message via AIM to varisystarter Send a message via Yahoo to varisystarter
Question Best turbo.....bov?
This car is to be an aggressive daily driver/weekend warrior(i love to drive, 65k in 2 years). i just bought an 99 gsx 5 speed unmodded, i have ordered a 3" turbo back and high flow cat, i'm considering purchasing an evo header(bad idea or good?). I'm in the market for a new turbo and bov(or internal waistgate). I've looked at 16g's and 20g's among anything else i could find. I am also unsure of what level of turbo timer to go with. And am i forgetting anything?
Old 11-25-2004, 09:04 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Best turbo.....bov?
I dont see any mention of fuel upgrades EVO16g is a good street turbo, and for a big street turbo the TDO6H 20g was my favorite. Anything bigger and you should really know what you are doing. I would probably suggest EVO16g, AFC, logger, 190, and 660s, since this will be mainly pump gas use. There are a lot of varaibles though.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 11-25-2004, 01:27 PM
joemathews's Avatar
joemathews joemathews is offline
16gs come internally gated for the wastegate--there isn't much need for an external wastegate with these turbos. You will need a bov regardless. Kevin's suggestion of the EvoIII 16g is the most popular street turbo right now, good for about 400 hp maxed out. Turbo timers all do the same general thing--let your car idle for a set amount of time, then shut it off. Each has specific features--the HKS type1 TT is probably one of the coolest (has features like a G-tech), although I like my Apexi pen-style personally.
You are forgetting:
1) datalogging system
2) fuel pump and injectors
3) fuel control
4) air filter and adapter
5) boost controller
6) less restrictive intercooler piping
1996 Eagle Talon
Old 11-26-2004, 03:16 AM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Do your research first. It appears that you aren't familiar with the difference between a BOV and wastegate? They are completely separate parts. I'm assuming you looked around a little and came across 16g and 20g as popular turbos. There are a lot more options. Check out the site list and look for info on the correct order to mod your car. The evo 16g or 20g would be my suggestion for you, but they both come with several thousands of dollars in supporting mods.
Stock exhaust manifold (you called it a header) is fine. Worry about flow after the turbo, which is o2 housing and back. Turbo timers don't have 'levels' so if you want one, get any of them.
Old 11-27-2004, 11:43 PM
o*HeR()'s Avatar
o*HeR() o*HeR() is offline
Banned
grow up and drive like a normal person...agressive daily drive , bring that shit to the track cause if i saw you fly past me ide laugh and say your a cool guy
Old 11-27-2004, 11:47 PM
o*HeR()'s Avatar
Banned
Re: Re: Best turbo.....bov?
how much more power will i get by setting my turbo timer on 30 seconds? Werd. lol j/p
Old 11-28-2004, 12:02 AM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
stupid post ^^^
and your sig is very annoying...can i shoot him....
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 12-03-2004, 01:57 PM
2of9 2of9 is offline
what are the Back-up mods for the 18 g turbo and the price of all the mods to back it up? i kno, but not really sure of the "back-up" mods to spool the 18g.
"i told you it was third, I lengthen the injector pulse another millisec and tuned the NOS timer, and you'll run nines"
--2OF9--
(DSM team specialist) ;D
#808/1000
Old 12-03-2004, 02:47 PM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Don't forget the most important mod of them all.....
Aftermarket boost gauge!!!!!!
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 12-13-2004, 08:59 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
why the 18g? i was stuck on that because of the very nice [and CA legal] GReddy kit. but really the EVO 16G flows just as much as the 18G and also just under the 20G.
try to get unstuck on the 18g like i was.
do a search on 18g and see what comes up [in AF]
lots of good info you will find... [that was a little Yodaish... lol]
Old 12-15-2004, 10:47 AM
thecackster's Avatar
thecackster thecackster is offline
Send a message via MSN to thecackster
^ ROFL, haha, i was like wow what the ef...but ya the 16g, is reccomended from what i read.
97' Chevy Silverado
K/1500 Z71
350 Vortec
Flickr My Website
Old 12-17-2004, 05:01 PM
hmmm...so the EvoIII 16g Turbo is the best recommended for street/race use, yeah, i kno for sure imma do this turbo, but like if someone ever is crazy enough to do the 18g? how crazy do you hafta do to the car?
--2OF9--
#808/1000
