Problem with Stealth
Alright, this has just recently started to happen, and everytime that I put on the gas, at about 3000 RPM'S i get this really high pitched noise and it continues on. The only way that there isnt that high pitched noise is if its below 3000 rpm's. and it's on every gear, so the problem im thinking is maybe a timing belt..?
![]() 1991 Dodge Stealth R/t |
you know what i had that exact same noise its like a high screetching noise right? anyways it went away after a while, but now it seems to be coming back. when stopped and i quickly accelrate it screetches very shortly about 1 sec and goes away. what is this dang problem?
Re: Problem with Stealth
I have no clue what the problem is, but like mine doesnt seem to go away at all. it just stays there and is annoying as all hell... and kinda embarrassing at some times.
yeah i bet its embarassing its even embarassing for me when im driving and my car it makes this clicking noise. i know its either the timing belt or the serpentine belt hoping the serpentine belt. i have this nice car but sounds like crap annoying!!!
yeah, and hopefully soon im getting rid of the ticking by going out and buying new lifters. I also heard that cleaning the lifters really good works too.. but i dunno. Might just go with new ones.
so you think that clicking noise under the hood could be a lifter tick? how much will that cost you? also my car does smoke when i rev it up cold then goes away after a short while.
Re: Re: Problem with Stealth
damn it so how much will this lifter tick cost? i looked on the faq and i didnt really get an answer.
they sell the 99 lifters for $300 on ebay...elsewhere much more. And yes the tick tick tick you hear is the lifters, and they arent damaged, they're clogged from what i've been told so they aren't hurting anything but your ears.
Did you do a compression test 3000-GTO before you ordered piston rings? |
Uhh, I think the schreeching noise could be the timing belt, my dad had the same problem with his car, and had to end up replacing the belt (but he has a 95 dodge ram van...)
ok so its definately lifter tick then dang it. ok what is the part called to fix this problem so i can look it up on ebay? also i dont want to get my timing belt changed since i am selling it. is there anyway to temporarily get rid of that screetching till after i sell it?
No I actully probably should have gotten my compression checked out first but I think that's what it is anyway. I just had my timing belt replaced so I know it's not that.
osok_deadeye_21--> Lifter tick will cost the price of lifters + installation (but you can always install them yourself!) Check the FAQ, i've posted an addendum to Lifter Tick, and there are 4 places i've found that you can get lifters for under $400. I also have found installation instructions, so i'll post them soon on the FAQ section. The dealer quoted me a price of $51.99 per lifter, which would come out to around $1200 for a set of 24. Also, expect to be charged a labor rate of $70 an hour!
Technical_Automan--> i'd be wary of getting internal engine parts off e-bay, unless you have some sort of gaurantee or assurance of product quality. In the FAQ i've posted the names/numbers of businesses that sell 3rd gen lifters. The main thing i would be worried with is whether or not the lifters are USED, REFURBISHED, or in the best case NEW. Keep in mind they are an internal engine part, so mechanical functionality is critical.
93 3000GT base K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2 coming soon: adj. cam gears | bi-xenon HID retrofit |
The Screaching Noise is the timeing belt... they do make a anti screach spray i hear that works... it just oil i think... and for loseing compression and white smoke just at start thats the vaulve guide seals... its very domenent on mitsubishis that the rubber seal will shrink and let oil into the cylender and loose compression.
![]() Upgrades... To many to list...
