Old 11-25-2004, 12:55 AM
angels7113 angels7113 is offline
daily driver turbo
is it a good idea to put a turbo on a daily driver or does it cause to many problems
Old 11-25-2004, 04:56 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: daily driver turbo
well in your everyday driving, assuming you drive normal, your not going to go into boost so it doesnt really affect yoru daily driving.
Team Lonely Drivers
Old 11-25-2004, 05:04 AM
Civic Jim's Avatar
Civic Jim Civic Jim is offline
Send a message via AIM to Civic Jim Send a message via MSN to Civic Jim
if u dont run silly pressure and drive like a nob i dont see why not
Jim - Your Resident EDM Biatch
B16A1 I/H/E
4TH GEN UK SITE
Honda Civic EE9 1.6-i VT
Old 11-25-2004, 05:12 AM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
buddy of mine was running 18psi on his daily driven talon, then he blew the motor, but thats because hes an idiot and ran 18psi on a stock bottom end. If its tuned right and its dependable, meaning you do all the math and its matched good for the engine and the other components you are running. Do all that you wont have any problems. There are alot of factory turboed cars.
Old 11-25-2004, 08:48 AM
icE_x's Avatar
icE_x icE_x is offline
Send a message via AIM to icE_x
if you drive like normal will you still hear the blowoff valve? i heard 6-8psi is good for most daily drivers
1990 Civic EX 4-Door Sedan - D16A6 - 204k miles
:: working on mechanical and cosmetic restoration ::
Old 11-25-2004, 08:48 PM
Hilikus Funkin's Avatar
Hilikus Funkin Hilikus Funkin is offline
Send a message via AIM to Hilikus Funkin
yeah ull hear it if your pushing to the point where its making alot of pressure. Alot of cars blow off at like 3-4k i think. Theres this guy around here with a 5th gen coupe turboed and he shifts at like 2.5-3k and you hear his blow off valve.
1991 Honda Civic DX Sedan
Old 11-25-2004, 08:49 PM
if you dont want to hear the bov sound then get an eclipse or talon stock one. I have one around my room somewhere...
Old 11-26-2004, 10:49 AM
icE_x's Avatar
i wanna hear it! cuz if i'm gonna spend a ton of money on a turbo kit imma be using it all the time in a fun daily driver, so i'm glad i'll be able to hear it ^_^
how much would a shop charge to put in a turbo for ya? ur already spendin a lot on the kit, might as well make sure someone installs it correctly, cuz i know jack about installing stuff in the engine bay. I'm an audio/interior guy
Old 11-26-2004, 10:51 AM
clawhammer's Avatar
clawhammer clawhammer is offline
Well, if you can hear the bov at 3-4k, in 5th gear 3k is 65, 4k is about 82 for me. So I'll say it might affect you.
Old 11-26-2004, 11:14 AM
icE_x's Avatar
bov goes off only whenever u shift doesnt it? and if you shift at like 2k or so you won't hear it, but only about 2.5k+ you'll hear it go off? And would the bov go off everytime you let off the gas in 5th gear? lol too many ?s
Old 11-26-2004, 01:54 PM
Juicy05 Juicy05 is offline
I dont see why it would be a problem, the evo's run 16 psi dont they?
Old 11-26-2004, 10:13 PM
Cjz89civic's Avatar
Cjz89civic Cjz89civic is offline
AF Premium User
Send a message via AIM to Cjz89civic Send a message via Yahoo to Cjz89civic
When ever your turbo spools and you let off the gas the BOV will sound. So let say your turbo spools at 3000 RPMs if you let off the gas under acceleration it will make the sound. If you let off the gas in the same car at 2500 rpms you will not hear it. BOV works on vacuum a sudden vacuum drop will open the BOV and then the excess charge(boost) will vent through the BOV port.
Mods: D16Z6 Turbo'd P28 ecu and Greddy emanage for fuel. FWD tire smoker
My first Civic love Died from 92 year old Fart not watchin out.
Old 11-26-2004, 10:14 PM
Cjz89civic's Avatar
AF Premium User
Re: Re: daily driver turbo
Ya maybe but there compression is low and they where desinged for that specific turbo setup.
Old 11-26-2004, 10:45 PM
icE_x's Avatar
ahh i see, so it's not when you shift but when you let off the gas above the spool rpm. The rpms go down when you shift gears, so that's why you hear it then. I learn lots on the forum
Old 11-27-2004, 12:24 AM
forcefanad forcefanad is offline
WRONG.....3000 would be when ur turbo is fully spooled....turbos spool throughout the revs....if u hear the turbo whisteling and ur boost gauge is over 0psi...then u will hear the bov if it doesnt have a dump tube. FOR EXAMPLE...one of my buddies had a 95 civic ls swap turboed....when i drove it u couldnt shift without hearing it...seriously at 1500 ud hear it if u were in 2nd gear or higher
