Go Back   Automotive Forums Car Chat > Honda > Integra
Old 11-24-2004, 11:05 PM
integra_type-R integra_type-R is offline
Send a message via AIM to integra_type-R
Radio Antenna wouldn't go up...
i own a 01 integra type-r and the radio antenna wouldn't go up
i remember it went up a couple days ago on the stock deck but now since i installed my deck it wouldn't go up anymore after blowing a fuse
i replaced the fuse aready...everything seems fine except for the antenna =[
hit me up thanks
Old 11-25-2004, 10:16 AM
pepsihatman's Avatar
pepsihatman pepsihatman is offline
Send a message via AIM to pepsihatman
Re: Radio Antenna wouldn't go up...
I dunno about the Type R specifically, but usually with any car, you have to make sure you get the signal wire for the power antenna connected to the new stereo deck. I used to work at Circuit City in the car audio, so I've seen this a few times. If this is indeed the case, then get a harness from your local circuit city, or best buy, and they should have one that will plug directly into your factory harness, and then go to a universal harness, and then one to go from the universal harness to the back of whatever deck you have.
~!~David~!~
1998 GSR, 86k miles, AEM CAI, DC 4-2-1 Ceramic Header.
Old 11-25-2004, 10:36 AM
kornflakes28546's Avatar
kornflakes28546 kornflakes28546 is offline
consider yourself lucky... i hate that long goofy ass antenna!
but try reseting the ecu (pull the ground cable from the battery for 15 sec and connect it again) this helps if you replace any fuse.
Old 11-25-2004, 11:41 AM
Re: Re: Radio Antenna wouldn't go up...
Lucky??!! LOLL!!! seriously tho i dislike that long antenna too ahhaha
as a mater of fact i should slap my self in the face...i mean i don't even use the RAdio lOLL!!!
but thanks tho guys...much appreciated =]
Old 11-25-2004, 11:45 AM
SiGNAL748's Avatar
SiGNAL748 SiGNAL748 is offline
Send a message via AIM to SiGNAL748 Send a message via MSN to SiGNAL748
Antenna Mast.
whats that?
Old 11-25-2004, 11:48 AM
SiGNAL748's Avatar
Its the antenna assembly. They can be had for fairly cheap, and are universal for all integras.
http://cgi.ebay.com/ebaymotors/ws/eB...category=46093
Check that out.
If you try out what pepsihatman suggested, and it still doesn't work. Then its highly likely that its the mast.
Old 11-25-2004, 11:55 AM
p0wered_by_acura's Avatar
p0wered_by_acura p0wered_by_acura is offline
ehh my antenna wont go down
Old 11-25-2004, 12:03 PM
Check that out.
oh man...imma try that out...thanks signal
Old 11-25-2004, 01:34 PM
rushb18 rushb18 is offline
Try the antenna power wire if you changed your stock out you might have miss hooked the wire up to the antenna i did the same thing in my g/f's 95 ls..You might have hooked it up but it might not be the right power connection you need..
Old 11-25-2004, 02:51 PM
fastcompany166 fastcompany166 is offline
Thumbs up Power antenna tip
A quick tip, for once you get it working... lubricate the mast periodically with silicone spray at each section end as you cycle it up and down. Do it 4 times a year and it will keep working smoothly for years.
Old 11-29-2004, 03:38 PM
V T E C H's Avatar
V T E C H V T E C H is offline
antenna
I am haveing problems with my antenna as well. I have a 95 GSR with a custom panosonic deak. When i turn the radio on or off i hear the motor for the antanna working, but the antenna remains up, any ideas what i should do?
Thanks, Ian
95 Integra GSR, I/h/e, 15" TSW wheels, short shift, front & rear swaybar, lowered 2", 93 GSR head & intake manifold
Old 11-29-2004, 04:23 PM
lube it up and you'll have to force it down gently. you might have to work with it a couple times but it should be fine after that
Old 11-29-2004, 09:04 PM
RickwithaTbird's Avatar
RickwithaTbird RickwithaTbird is offline
Send a message via AIM to RickwithaTbird Send a message via MSN to RickwithaTbird Send a message via Yahoo to RickwithaTbird
yea, if you cant get it up, put some lube on it and try to work it up and down gently, maybe have your girlfriend help you by pressing your buttons while you try to get it going. If that doesnt work then you may have what is called a.d. which is antennile disfunction. Lets hope it aint that.
