Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 11-24-2004, 09:01 PM
ArideII's Avatar
ArideII ArideII is offline
Question Check engine light after intake install
I'm gonna get a code a reader to decipher the code, but since tom. is turkey day places will be closed.
I rechecked all my wiring and it is done correctly. I took the car out and it still seemed to run fine. Vtec kicked in, all seemed good... Does anyone happen to know what might cause this on an S2000??? Should I try to reset the ecu?
Comptech says that if the air control solenoid valve is wired wrong it can trip the check engine light. I went back and double checked my wiring, it was done correctly?!?!?!?
BTW, what the heck does an air control solenoid valve do?
Thanks
6spd Accord Sold, but you can still admire it, as I do, at
http://rwagner42.brinkster.net/6spdaccord.htm
2001 S2000 Currently -- Comptech Intake, Neuspeed Springs, Neuspeed Cat-Back Exhaust, Air/Fuel guage, Nitrous Pressure Guage, TPS, Remote bottle Opener, 2 Step Colder Plugs, NX Wet 75 Shot, 4.57 Gears, 5% tint.
2005 Mustang GT: Working on C&L Intake w/ Tune, Pro Kit, Wet 75 shot. Shooting for Mid 12's.
Old 11-24-2004, 11:04 PM
ArideII's Avatar
Never mind... I found a loose adapter. Tightened it, reset the ecu and it ran at idle for about 4 minutes and nothing came on.
