Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-24-2004, 07:37 PM
trackboi06 trackboi06 is offline
cmp sensor problem/hard starting
when i start mi car only 2 cylinders are firing but when i unplug the cmp (camshaft position sensor) all 4 cylinders are firing but its takes awhile to start..what is the problem???how can i fix this problem?plzz help
Old 11-24-2004, 07:53 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: cmp sensor problem/hard starting
it sounds like you need a new cam sensor
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 11-24-2004, 07:56 PM
i have bought a new sensor and it still does same thing. any other ideas??
Old 11-24-2004, 08:15 PM
did you align the sensor right? if its the same as a 1g you can install it with the sensor part 180 degrees off without any way to tell. try pulling it off and turning the sensor 180 then put it back in
-1stGenRocks-
Old 11-25-2004, 12:11 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
any cel's?
DSM geek
Old 11-25-2004, 02:19 PM
i just tried turning it 180 degrees to see if it resolved the problem..same thing happens.
Old 11-25-2004, 06:45 PM
any more ideas for the solution to my problem??
