Old 11-24-2004, 08:33 PM
Sfrid073 Sfrid073 is offline
Code 0446
Having EVAP problems. Getting a code 0446. Kid at AutoZone says it is comming up twice. Same code. I replaced the gas cap twice. Once with cheapy one from AutoZone, second from the dealer. Still have the SES light. Even after a few driving cycles. Then I changed the solenoid valve under the hood. Still no changes after driving cycles. I had read on here about another valve at the rear of the vehicle??? I have a 1997 Blazer 4WD. I checked the hoses and metal lines that run front to back and can't find a leak. Any help would be appreciated.
Old 11-25-2004, 04:48 AM
davydawg davydawg is offline
Send a message via AIM to davydawg Send a message via MSN to davydawg
i have the same problem, dont know what it is,, drives fine
Old 11-26-2004, 06:22 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Code 0446
condensation in the system also causes this problem.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 12-03-2004, 09:29 AM
ok....pulled neg battery to clear codes. SES light stayed out for a day. The day after it came back on. Any other ideas? If it is condensation how do I get rid of it?? And is there another valve/switch I need to check????
Old 12-03-2004, 02:23 PM
BlazerLT's Avatar
AF -Advisor
Re: Code 0446
There is usually a solenoid that can be swapped out to repair the problem.
It gets damaged by water getting into the system from not keep ing the tank full at all times.
Old 12-03-2004, 06:30 PM
I replaced the solinoid. That was in my first post
Old 12-03-2004, 07:52 PM
BlazerLT's Avatar
AF -Advisor
Re: Code 0446
My apologies, sorry about that.
Also, some people have a defective seal in the gas tank cap.
Old 12-03-2004, 08:09 PM
replaced gas cap also. it was also in my first post
Old 12-03-2004, 09:38 PM
BlazerLT's Avatar
AF -Advisor
Re: Code 0446
Oh god, I'm not havnig a good day.
Forgive me.
Old 12-04-2004, 02:29 AM
the p0446 code says Evaporative Emission Control System Vent Control Circuit Malfunction , were is the vent control circut, is it in that solenoid?? were is that solenid anyway, is it under the hood or by the evap can???
Old 12-06-2004, 06:05 PM
boomer62 boomer62 is offline
Re: Code 0446
MY 99 blazer had the same problem. There is a solenoid/valve behind the gas tank, but in front of the spare tire. You have to remove your spare tire to get to it(if your spare is under the truck). cost me 200.00 to diagnose an install and 35.00 for the part. Hope this helps.
Old 12-07-2004, 01:03 PM
scholzee scholzee is offline
My 2 dr 1996 the solenoid is at the front top of the gas tank just behind the rear axle it looks like this.
http://catservices.wrencheadpro.com/...EM/162-440.jpg
Old 12-09-2004, 02:24 AM
thanks guys i am going to pull my spare and check it out tonight
Old 12-09-2004, 02:43 AM
BlazerLT's Avatar
AF -Advisor
Re: Code 0446
Let us know.
Old 12-09-2004, 07:07 AM
Forgot to mention on my other post but my 1996 could have one of two versions the other looks like this http://catservices.wrencheadpro.com/...EM/162-424.jpg
They may be also part of the charcoal canister, my canister is located behind the drivers rear wheel in the bottom of the quarter panel, so if you do not see it by the gas tank look for your charcoal canister.
