Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 11-24-2004, 06:07 PM
srm2000mac srm2000mac is offline
Question Kyb AGX's
My 97 GST came with Kyb AGX shocks. I know where to adjust the front to but the ones on the rear are covered with junk. I cleaned them off and can now see the 1-8 on the dial but I don't know what to line the numbers up with. Does the 1 sitting at the top, or the highest up on the dial mean it is at the softest setting or is it supposed to line up with something else?
Old 11-25-2004, 12:12 AM
o*HeR()'s Avatar
o*HeR() o*HeR() is offline
Banned
Re: Kyb AGX's
highest might be the hardest
Old 11-25-2004, 08:53 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Kyb AGX's
Low is soft, high is stiff. On a 1g FWD my buddy had real good luch setting the rear to 8. Very noticeable improvement in traction, especially 2nd gear.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 11-25-2004, 10:38 AM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: Kyb AGX's
if you still dont know where to point the numbers to just spin the knob all the way in each direction and see what the highest and lowest numbers line up with.
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
