Old 11-24-2004, 11:49 AM
simmsm simmsm is offline
problem, brake pads
I assisted my mechanic replace brake pads last time. I am on my on now & I don't remember the steps. Who can help me on this one?
Old 11-24-2004, 06:17 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: problem, brake pads
Loosen the wheel and jack up the vehicle. Remove the wheel and tire and you will see the brake caliper. Remove the bolts that hold the caliper on and remove the caliper from the rotor. If the rotors need replaced do it now and use a lug nut to hold it in place. Otherwise, just use the lug nut to hold the rotor steady. Now remove the pads from the caliper and use a c-clamp to compress the piston of the caliper. Replace the pads, use shims or brake quiet to insure no vibration. If you are using premium pads they usually come with shims. Replace the caliper on the rotor and tighten the caliper bolts. You may want to lubricate the slides with brake grease so they slide easily. Remove the lug nut reinstall the wheel and repeat on the other side. Good Luck!
Old 11-28-2004, 07:15 PM
chigger_ns chigger_ns is offline
Also make sure the little anti-rattle clips are in good shape or you will have an ungodly noise except when you put your brakes on. Theseclips are on the corners of the calipers there the pads touch them.
