Old 11-24-2004, 12:10 PM
jwo21 jwo21 is offline
High speed brake failure
I recently changed the rotors and brake pads on my 1994 Blazer s-10 and everything works fine while driving at slow speeds around town. But when braking at high speeds (like an off ramp on the interstate) the brakes will feel as if they suddenly fail but then will come back to normal after a few seconds. This only occurs when I am braking at speeds over 60 mph. When the brakes are engaged they will function normally at first and then the pedal will sink and it feels as if the brakes go out and they mak an odd noise, then after 2-3 seconds the brakes will re-engage and the pdeal will feel normal again. Since noticing this I have taken it to a mechanic who replaced the calipers and bleed the brake fluid, but the problem still exists. Upon taking it back the mechanic adjusted the rear brakes but that still did not cure the problem. Any help would be appreciated.
Old 11-24-2004, 12:31 PM
IGOTTABLAZER2 IGOTTABLAZER2 is offline
Unhappy
Sound likes your Calipers are getting stuck!
Old 11-24-2004, 12:42 PM
I'll check them again. thanks
Old 11-24-2004, 08:12 PM
Mikado14 Mikado14 is offline
Re: High speed brake failure
I'm just gonna pull this out of the south end of a north bound horse but does this noise sound as if the ABS is functioning? The year of your truck makes me wonder.
Old 11-26-2004, 06:24 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Brake booster failing?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 11-29-2004, 09:25 AM
I'm not sure what it sounds like when ABS fails, so I couldn't tell you for sure. It sounds like all of a sudden there is a lot more road noise and then after a few seconds it goes away. Do 1994 Blazers have a problem with the ABS or is just because it getting old?
Old 11-29-2004, 10:03 AM
I know there is a recall that would give the results you are talking about. The problem is a sensor and it will not trigger an ABS light. What it does is activate the ABS when it is not needed and will cause longer stopping distances. This was on 1st Gen Blazers. Not too sure what years or any more specifics but I am sure you can either look it up on the net or go to your local dealer. Also, from what I am told, this was a recall and it has no time limit.
Good Luck
