Old 11-24-2004, 10:39 AM
dgreggs dgreggs is offline
Send a message via AIM to dgreggs
ABS Light On
My ABS light came on in my 98 cavalier RS. No other engine lights came on. My brakes work fine, but when I tried to test the ABS on a rainy day it did not kick in. I was told it might be the ABS relay by the battery, but when I tried to replace the relay at Autozone they told me it could NOT be the relay; it has to be the brakes. Fuses are fine. I am still thinking its the relay. I tried disconnecting the relay and the reapplying and the light is still on. BTW..brake fluid is normal. Please advise.
Old 11-24-2004, 06:23 PM
sirk798 sirk798 is offline
Send a message via Yahoo to sirk798
check the wireing around your wheel speed sensors.... your brakes will work fine so long as your abs light remains on. if it flashes your brakes are in jepordy... i would be willing to bet, you have a broken wire from your wheel speed sensors.. hope this helps..
kris
Old 11-29-2004, 04:39 PM
Smile
The day I take my car to my buddies house to see which sensor is bad, the light goes out and my ABS works as usual....Go figure
Thanks for the response
