Old 11-24-2004, 10:11 AM
chazpaul chazpaul is offline
no power to purple starter wire
93 Z28 a/c, at, abs, power windows and locks, has oem resistor ignition key, jump purple wire car cranks starts up for 2 to 5 seconds. if carb clean down the intake will run fine, has injector pulse only for two seconds, then nothing. fuel pump pressure is at max 46-48psi. lowest fuel pressure is 40psi.
Old 11-24-2004, 06:32 PM
4onFloor's Avatar
4onFloor 4onFloor is offline
might be a VATS problem. try cleaning the contacts on the resistor pellet, and on the inside of the ignition
Old 11-25-2004, 12:09 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
Re: no power to purple starter wire
definately sounds like vats, the two orange wires on the ignition lock cylender often break, so that the vats system gets an infinite resistance which dosnt match the key, and it cuts power to the starter, ignition, and fuel.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
