Old 11-24-2004, 07:37 AM
Heep's Avatar
Heep Heep is offline
Send a message via AIM to Heep Send a message via MSN to Heep
Oh this is beautiful.
The system is missing or corrupted.
Lovely.
Windows\System32\Config\System Corrupt or Missing, gives me this error on booting, then just reboots itself, then gets the error again, continually. I booted up with a simple boot disk, and replaced the "system" file with the "system.sav" that was in that same folder, and rebooted. Part 2 of XP Setup starts, installing all the hardware (I can only assume this "system" file contains all the hardware info then). After wasting 30 minutes of my time installing drivers and such, it then says there's a fatal error with setup, and to reboot and try again. Does it every time.
So, erm, help?
________________________________________
Mark Brown
1991 Volkswagen Jetta (1.8L I4/5-speed/FWD)
Old 11-24-2004, 08:43 AM
Neutrino's Avatar
Neutrino Neutrino is offline
Yaya Master
Send a message via AIM to Neutrino
Re: Oh this is beautiful.
Boot off the win xp cd and select the repair option. It should replace the corrupted files.
(\__/)
(='.'=) This is Bunny. Copy and paste bunny into your
(")_(") signature to help him gain world domination
Old 11-24-2004, 08:52 AM
Heep's Avatar
Re: Re: Oh this is beautiful.
How do I do that though? I put in the CD, set the BIOS to read from the CD before the HD, but it doesn't read it and continues to boot off the HD
Mark Brown
Old 11-24-2004, 08:54 AM
Neutrino's Avatar
Yaya Master
Re: Re: Re: Oh this is beautiful.
do you get the message: "press any key to boot from the cd"?
(\__/)
Old 11-24-2004, 09:14 AM
Heep's Avatar
Nope.
Mark Brown
Old 11-24-2004, 09:23 AM
Neutrino's Avatar
Yaya Master
Nope.
weird, well you said you already set the bios to boot from the CD-ROM, if you have two optical drives you might have the CD in the slave drive and that might not allow it to boot. So switch in the other drive and try again.
In case your bios has the boot order listed as ide1, ide2 ide3.....make sure you have the right ide selected.
also check for small mistakes like: when exiting the bios after selecting to boot from the CDROM make sure you exit while saving the changes. Also make sure the CD is properly inserted and its not scratched to deth.
(\__/)
Old 11-25-2004, 04:46 PM
Heep's Avatar
Found out the computer was too old to boot from the CD, so I got the program from the MS website that creates XP start up disks for you. The computer had been getting very slow and clogged, so I had been considering a reformat and reinstall, so I figured now would be a good time to do it.
Working like a charm now
Mark Brown
Old 11-25-2004, 05:02 PM
Neutrino's Avatar
Yaya Master
Dang I did not think of that, what the heck you running a P2 or a K6?
Anyway as a Chinese fortune cookie would say: " The path to enlightement is trough upgrade"
(\__/)
Old 11-25-2004, 06:57 PM
Oz's Avatar
Oz Oz is offline
Aussie Mod
Send a message via AIM to Oz
Now that you're back up and running, check if there is a BIOS upgrade so you can boot from the CD in future.
I went down this path recently when installing XP SP2 and it ballsed up and I had a meltdown here at the office.
Originally Posted by RaeRae1
Blessed are the cracked ones for they are the ones that let in the light.
Old 11-25-2004, 09:36 PM
Heep's Avatar
AMD Duron 1.3GHz
Just old BIOS I guess.
Mark Brown
Old 11-25-2004, 10:11 PM
twospirits twospirits is offline
Ex-Janitor of AF
Go to your motherboards website and download the bios and install it like Oz said, but make sure you follow the instructions otherwise you will not be able to get in. I had to do it recently on one of my older PCs here at home.
TS out
The more the members are involved in the process of development, the better we will be as a community of Automobile enthusiasts. Have a suggestion to make the community better, let us know.
Remember, the "No" is always there, you are just looking for the "Yes"
Members please read: Guidelines
