Old 11-24-2004, 07:21 AM
quiXilver's Avatar
quiXilver quiXilver is offline
Send a message via ICQ to quiXilver Send a message via AIM to quiXilver Send a message via Yahoo to quiXilver
Is there a way to tell if a block is bad?
I was just wondering if like maybe the block has cracked somewhere on the inside? Anyway to tell if the block is cracked/warped?
http://www.cardomain.com/quixilver09
B18A
-It's always somethin'
Old 11-24-2004, 07:44 AM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: Is there a way to tell if a block is bad?
magnaflux it or go over it with a torch with a carbon flame, the carbon deposits will settle into cracks.
Old 11-24-2004, 08:49 AM
quiXilver's Avatar
Re: Re: Is there a way to tell if a block is bad?
So I would take everything out of the block then take it to get magnafluxed?
B18A
Old 11-24-2004, 08:54 AM
Forunn Daberator
yeah strip it, you can buy magnaflux kits I think where you can do it yourself, I'm not real sure whats involved in doing it. I think you just degrease it real good then you spray a chemical on it and it shows up in cracks, but dont quote me on that.
Old 11-24-2004, 09:27 AM
quiXilver's Avatar
Well there was water mixing with my oil, and when you take the dipstick out and the motor is running, it'll spit oil out at you. What should I do? I have stuff to rebuild the bottom end, but how do I know the block isn't bad on the inside?
B18A
Old 11-24-2004, 09:32 AM
Forunn Daberator
heh sounds comical, like one of those movies where there working on a car and turn something with a wrench and oil shoots them in the face.
Run a compression test yet?
Old 11-24-2004, 09:52 AM
quiXilver's Avatar
Too bad this isn't comical at all. I haven't done a compression check yet. I already took the head off. Anyway I can still do it without the head on?
B18A
Old 11-24-2004, 04:30 PM
Forunn Daberator
nope. This sounds like one of those things your not going to be able to diagnose untill you pull it appart. Maby someone else has some insight thats brighter than mine.
Old 11-24-2004, 05:22 PM
Hilikus Funkin's Avatar
Hilikus Funkin Hilikus Funkin is offline
Send a message via AIM to Hilikus Funkin
uhhh when u take the distick out when its running it usually does spit oil out, not alot but a lil.
1991 Honda Civic DX Sedan
Old 11-24-2004, 06:23 PM
Kunundrum's Avatar
Kunundrum Kunundrum is offline
Send a message via ICQ to Kunundrum Send a message via MSN to Kunundrum
could be head gasket, compression + coolant + oil = one ugly mess
does your oil turn white ?
2012 VW Golf 3 Door Automatic (Company Car)
2011 VW Golf Wagon 5 speed (Company Car)
2010 VW Jetta 2.5 Automatic (Company Car)
2009 VW City Jetta 5 Speed (Company Car)
2009 VW GLI 6 Speed (Company Car)
2008 VW Jetta 2.0T 6speed (Company Car)
1999.5 Audi A4 Quattro Sport 1.8t (Chipped 1.0 bar) Sold
1990 CRX Si (Built B17a) - Stripped and Crushed
1988 CRX Si -- Stolen
1990 Civic Cx -- Sold
1990 Civic Si -- Parted
1989 Civic dx -- Sold
Old 11-24-2004, 11:00 PM
quiXilver's Avatar
Yes, I pulled the head off yesterday and most of the oil sitting in the grooves was very milky.
I just don't want to rebuild the bottom end then have the block fucked up or something ya know?
B18A
Old 11-25-2004, 12:30 AM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
First of all magna flux is only for cast iron blocks/heads. What you will need are these 2 penetrating dyes. Ask you local mechanic about it. If your crankase is pressurized (oil spitting out of dipstick), possibly blown gaskets, etc. you may want to look into getting a new pcv valve. your old one might get clogged up which will prevent your motor from being able to relieve pressure that gets built up in the block.
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 11-25-2004, 03:13 AM
Forunn Daberator
yeah I remembered that magnaflux was for iron blocks earlyer.
