No bottom brake lights
My L and R bottom brake lights will not work, the top middle one works fine. The turn signals work and 4 ways work also and all fuses are good too. This is a '95 Monte Carlo.
Any ideas would be appreciated. Thanks Last edited by gm3matt; 11-24-2004 at 09:12 AM. |
Re: No bottom brake lights
turn signal switch,common on lumina's and monte carlo's
Re: Re: No bottom brake lights
Thanks for the replies, it does seem to be the problem.
I was messing around with the turn signal switch on the column and when I pulled slightly forward the tail lights would then work. Does this mean I have to replace the switch or can I simply adjust it some how? Anyone know? |
You will have to replace the switch it will be called a multifunction switch or a turn signal switch. most of your major parts stores will have it try to get one made by borg warner its better quality and a lifetime warranty beyond any warranty the parts store will give.
Great!
Thanks for your help. Matt |
