Old 11-23-2004, 10:12 PM
I-Eat-Civics I-Eat-Civics is offline
Send a message via AIM to I-Eat-Civics Send a message via MSN to I-Eat-Civics Send a message via Yahoo to I-Eat-Civics
How much boost on stock motor?
I'M trying to a buy a talon 95 TSi AWD Turbo. Im just wondering what the compression On the 95 tsi is and how many lbs of boost i can push with switching turbos to a T70
The 91 LS no Longer Lives www.RIP91TEG.piczo.com
__________________________________________________ ___________
1995 Acura Integra GS-R:
Blown Motor Waiting for swap
Old 11-23-2004, 10:17 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: How much boost on stock motor?
wtf is a T70? as for boost on the stock turbo. try searching you will find hundreds of threads answering your question. ill be nice and tell you that with the free mods you can usually boost up to 20 but it is best to boost about 15 since above that the turbo heats the air too much.
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 11-23-2004, 10:19 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
400 hp on stock internals....
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 11-23-2004, 10:22 PM
97dsmeclipse's Avatar
97dsmeclipse 97dsmeclipse is offline
Send a message via AIM to 97dsmeclipse
have fun trying to push a t-70 turbo on a little 2.0 non built up 4cyl, if i was you i would start with a big 16g, 20g, or a T3/T04. Im not for sure on this one but i think someone said the compression is like 8.1:1 or some where around that, dont hold that against me im not for sure just go on google and look.
Bottles are for babies - Real men get blown!!!
Car pics
97 eclipse rs - Sold
99 eclipse gs - Blown Motor
97 eclipse gs-t - For Sale
98-99 eclipse gs-x - - Looking for one
Old 11-24-2004, 09:56 AM
kjewer1 kjewer1 is offline
AF - Advisor
1G compression is 7.8:1 (~160 psi)
2G compression is 8.5:1 (~175 psi)
Its not about how much boost you can run, its about how much airflow you can run. But the rule of thumb is ~15-16 psi on stock fuel system with normal mods (exhaust, filter, UICP, etc). I've posted about this extensively in the past.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 11-25-2004, 04:05 AM
Talon_ESi Talon_ESi is offline
Send a message via AIM to Talon_ESi Send a message via MSN to Talon_ESi
The stock internals can SAFELY handle 300-400MAX horsepower and if you upgrade to the third generation lifters and upgrade the cams and gears, you can SAFELY run 10-16MAX boost on stock rods/pistons, anything more than that I would get Eagle"H" rods and forged pistons.
Old 11-25-2004, 09:09 AM
AF - Advisor
I've run 30 psi on stock motors, as have a hundred other DSMers. Both 6 bolt and 7 bolt internals are making over 500 WHEEL HP reliably. Lifters cams and gears hae nothing to do with how much boost or power you can run, but cams will allow more power with less boost (airflow/pressure goes up).
So again I say, it has nothing to do with boost pressure, and more to do with airflow. And its all about matching that airflow with fuel. I can elaborate more on this if people want, and there is some info on my site on the "AFR and blown motors" page. At the bottom there is a spreadsheet that will tell you how much airflow a given set of injectors can support, and how much airflow several different pumps can support, and you can input boost pressure, fuel specific gravity, and AFR.
Kevin Jewer
