No Tac.
Well, my sister is selling me her 99 Cavalier in gooooood shape for only 800 dollars, i took it out for a spin and it has no tac. It is a 5 speed manual. So, my question is, is there an EASY way to add a tac to my newly acquired cavalier, iplan on making it a sleeper.
Re: No Tac.
Tachometer Installation for a 1998+ 2200 Engine
You Will Need: 12V Test Probe Wire Cutter Wire Stripper Extra 12-16 Gauge Wire Wire Connector Butts Wire Loom or Sleeve Hose Electrical Tape 4Amp or 5Amp Fuse Cartridge Fuse Metric Wrench READ INSTRUCTIONS CAREFULLY Look for a desirable place to mount your TACH and mount it. NOTE: Be careful not to drill a whole on a week spot, and make sure that none of the TACH parts is leaning on the windshield. Using a wire loom and electrical tape, neatly tuck the TACH wires on the side of the dash going down to the foot pedals. After mounting the TACH, remove the cover on the fuse box and the outer side dash cover. Also, open the fuse box. Clip the 12V test probe to a good ground connection. Don't use the door or the body of the vehicle, instead, there's a good ground connection under the hood, close to the windshield wiper motor. THERE ARE FOUR WIRING CONNECTIONS THAT WE HAVE TO DETERMINE. White Wire - 12V Dash Lighting (+) Red Wire - 12V Ignition Switch (+) Black Wire - Good Negative Source (-) Green Wire - TACH Terminal from the PCM First: WHITE WIRE - 12V Dash Lighting To determine a 12V dash lighting, turn the headlight switch on, and using your 12V test probe, test some empty slots on the fuse box. If you've found a slot that turns your test probe light on, turn the headlight switch off and test that slot again. If the test probe light is off, then you've found your 12V Dash Lighting connection. You will need to unscrew the fuse box to be able to work on easier. Using the wire stripper and cutter, cut and connect the WHITE WIRE from your TACH to the 12V dash lighting that you've found. Make the connection neat, clean, and accurate by using a connector butt. Second: Red Wire - 12V Ignition Switch To determine a 12V ignition switch, turn the ignition on, (but don't crank the engine) and using your 12V test probe, test some empty slots on the fuse box. If you've found a slot that turns your test probe light on, turn the ignition switch off and test that slot again. If the test probe light is off, then you've found your 12V Ignition Source connection. This time, you will need to use a 4Amp or 5Amp fuse to make the connection. Cut and strip the wires properly and connect the Fuse Cartridge along with the 12V ignition source you've found and the RED WIRE from your TACH. Do not install the fuse until you are ready to calibrate the TACH. Use connector butts to connect the wires properly and neatly. Install the fuse box into its place. Install the Fuse Cartridge to an accessible area, where you can change and install the fuse (the right side of the fuse box is a good spot). Install the two parts of the dash. Using an extra (2-3M) 12-16 gauge wires, strip and connect the BLACK and GREEN wires to extend the length. Neatly tuck the wires underneath the dash and find the firewall or the hole where wires are directed to the engine compartment. Then run the BLACK and GREEN wires through the firewall into the engine bay. THIRD: Black Wire - Good Negative Source If you can connect it directly to the Negative source of the battery, it would be great. If you can't, then there's a good negative source right beside the A/C blower or fan - it's one of the major source of ground - you can't miss it. It is connected to the body of the vehicle. Connect the Black Wire from your TACH to the negative source, making sure that the wire is not excessively long. FOURTH: Green Wire - TACH Terminal from the PCM Locate the PCM (Refer to a shop manual for location). There are two slots of connections for the PCM. The upper part (which is BLUE) and the lower part (which is BLACK). Using a wrench, unbolt the lower part (BLACK), making sure not to damage the gasket. Remove the light blue face for easy access to the wires. Locate PIN #10, it is WHITE WIRE. Remove some of the electrical tapes for more access to the wire. Cut, strip, and connect the white wire to the Green Wire from the TACH. Use a connector butt to properly connect the wires. Tuck neatly all excess wires using wire looms and electrical tape. Now you're ready to Calibrate your TACH. Follow the instructions that came with the TACH on how to calibrate it. ~ NY-jbodies.org http://www.ny-jbodies.org/forum/libr...achinstall.htm
Please don't PM me with your J-body Issues. Post appropriately in the forums, and I will toss my opinion in your thread if I have anything to help. - Thanks! 2006 Chevrolet Trailblazer 2010 Glastron GT 205XL |
Re: No Tac.
not unless you want to spend a lot of money cuz it has d.i.s its a pain and you need a special addapter to get it all working. i was thinking of doing the same then i found out it was gonna cost me
what my speedo only goes up to 190??
Re: No Tac.
Hey 200plus... save your self some money and follow the above steps... great fun and a way to kill a few hours...
